Old 11-05-2011, 10:24 AM
CC1650Dave's Avatar
Ha - I can't tell where we're at on the camshaft/crankshaft matching thing now.
Matt, I did get a picture, but you can't actually see the crankshaft mark on it, so it's inconclusive evidence. Besides, I had to match them several times because I had to remove and reinstall the bearing plate trying to get the spacing right.
I wonder if one could get one of those little inspection cameras into their block to take a look at this? Maybe go in through the fuel pump hole...
Wouldn't pulling the head and bringing it to TDC and checking the site hole and seeing T stamp mean that the cam and crank are timed correctly?
I was thinking along those lines when I re-checked the valve clearances Duke. When I got the cylinder into position for valve adjustment, I could see the T in the window, although it appeared as though there was some play before and after the T. Of course, I didn't have the head off so I couldn't see exactly where the piston was.
Dave, if you pull the fuel line off the carb do you get good flow from the tank? Maybe jump 12 volts to the coil to to bypass any problems in the ignition circuit like Pulse said. Try another Autilite 216 plug. WTF this thing should run
Yes, good fuel flow. The bowl fills right up as well. The 12V jump is one of my next steps. Another plug? OK, but as a last resort. Lots of other things to check thru first...
Thanks guys!
Old 11-05-2011, 06:05 PM
No, because the flywheel is connected directly to the crank. That has nothing to do with the cam position, or it even being there, for that matter.
Old 11-06-2011, 01:30 AM
There goes that idea. Thanks for the input!
Old 11-10-2011, 10:41 PM
Yo Dave, where are we at on this engine? I'm wanting to know if she's runnin yet.
Old 11-10-2011, 10:45 PM
Sugarmaker's Avatar
Dave,
Like others whats up with the engine! Hope things are good.
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 11-11-2011, 03:27 PM
CarBiz's Avatar
CarBiz CarBiz is offline
WHOA.......... great job Dave i would have never gotten this far i would packed it in by now!!
Let me know if i can help in anyway though i'm not very far from ya
Old 11-11-2011, 06:03 PM
CC1650Dave's Avatar
I actually got a little frustrated with the whole idea and decided to let it rest for a little while. Not quitting, just backing off for a bit.
Not to mention that we're done mowing, and not yet snowthrowing...so I don't have any big push to get it rolling.
I think I'll go after it this weekend and see what I come up with. I'll typically be either "all in" or "all out," so this weekend may yield some results (or further frustration.)
Thanks for providing further motivation though guys! That's one of the great side benefits of documenting my project here. I don't feel like it's just me and the Cub!
Old 11-11-2011, 06:23 PM
No rush!!??
You live in Michigan, you got what, 18 hours 'til it snows??
Just kidding, I feel your pain,
in Virginia sometimes we get snow that needs moved in ..............
................. February ... LOL
We are stuck still mowing in December!!
Poor Duke must mow close to year round!!
We are here to hear your problems!
Solutions are as good as what you paid!!
Old 11-11-2011, 06:27 PM
CC1650Dave's Avatar
We actually did get snow yesterday. First time I can remember it snowing this early in a long time. It was just enough to barely stick to the grass, though.
I also need to get the boat winterized this weekend, and get my 870 sighted in for the start of gun deer season on the 15th.
Old 11-11-2011, 07:13 PM
Sugarmaker's Avatar
Dave,
Yes deer season starts to take over my priority at this time of year. Take a break.
My son restored a mini Honda three wheeler years ago. He finished it. Pulled the cord to start and it did not fire. He went all through it. He finally found that the new plug was junk! put in a new plug and it fired the first time.
Good luck sighting in the 870! I need to do that for the 7600.
Regards,
Chris
