Old 09-14-2011, 06:23 PM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
Did some cleaning of the block and valve/piston area and think I know why I seen new cross hatching in the cylinder area. When I cleaned up the top of the piston, the sure sign of .010 was stamped on the top of the piston. I thought that the piston looked extremely clean and the block looked as good as well. Like I said before,this motor ran with alot of power,it was just bypassing the oil. I cleaned up the head and the only oil soaked,carboned up area was the exhaust area. I ordered new valves,springs and head gasket from Tulsa Engine and when they get here,I will try to see if this motor runs better..
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 09-15-2011, 10:17 PM
Rhoderman's Avatar
Rhoderman Rhoderman is offline
Pat (& others), I'm just not seeing how you are pulling that much oil through the valve guide(s). Exhaust is a no-brainer, the pressure is in the wrong direction. Intake I can see where some manifold vacuum would pull some oil in, but it's an uphill battle and the oil would have to come all the way up from the valve cover area, which the valve cover should allow air to pass, and oil really shouldn't be flooded up in there anyway.
If you spin the engine a bunch of times, do you get a bunch of oil on the cylinder walls, like it's getting by the rings?
Was your valve cover gasket installed correctly to allow it to breathe and also the oil to drain back through that little bitty hole? I'd expect that to make the oil run out the valve cover vent holes though.
I do hope your valve guides fix it, and I'd really like to know if/when it does, just to add it to my "stuff I learnt" list in the back of my mind. I also wonder if maybe your rings aren't broken in yet because someone went overboard with honing or screwed something up during the apparent rebuild you've observed. Never trust someone else's work... Good Luck and Best Wishes on your valve guides.
Jim in Lafayette, CO
Cub Cadet 122, 126
Old 09-16-2011, 09:06 AM
As I posted earlier,if it were mine I would be looking @ the rings/cyl.
Maybe p.o. made a goof or possibly broke a ring on install or used std rings on a .010 over, who knows.
It don't take that much more to look deeper.
but I'll be quiet wishing him the best of luck.
Old 09-16-2011, 10:30 AM
cubs-n-bxrs's Avatar
That was my thought also. Either a broken ring or the rings ends were not staggered correctly. BTDT
Old 09-16-2011, 11:47 AM
hydrocub hydrocub is offline
X 2 what ol'George said ......
Happy wrenching
Old 09-16-2011, 07:55 PM
lukeott lukeott is offline
Default i agree
broken ring or not installed right. my 2cents.
luke
