Old 09-06-2011, 10:06 PM
Awesome work! Keep the pics coming!
Old 09-06-2011, 10:14 PM
william1041200's Avatar
ED! hopefully, I can catch this one before it happens: DO NOT SANDBLAST THE ENGINE!! Tins, bolt on parts ok, but do not expose the internal casting to sand! Guess how I know... I heard the news after I did it, but the damage was done. There is no way to get the glass/ sand/ media out of the cast, and it finds its way around with oil flow.
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 09-06-2011, 10:51 PM
Excellent point. On the same token, please tell us you didn't sandblast the rearend...same problems will occur...
Old 09-06-2011, 11:47 PM
Arrowhead's Avatar
Arrowhead Arrowhead is offline
I cleaned the block in an ultra sonic cleaner. The tranny I used cup brushes on the grinder. I used brass bolts on the seat bracket because I had them laying around for years now and figured they would be sufficient for the seat.
Ed
Essex, IL.
Old 09-07-2011, 06:52 AM
Brass bolts are not very strong...I would replace those with grade 5 bolts, which is what was originally used on there. You certainly don't want those to break while you are on it and cause you to get hurt.
Old 09-07-2011, 06:58 AM
nikster's Avatar
nikster nikster is offline
Looks GREAT,
Nik,
Old 09-07-2011, 07:08 AM
mrjeep81's Avatar
mrjeep81 mrjeep81 is offline
Default me too!
I also am very motivated looking at your progress and quality of work. Looks very nice.
1450SGT
1641
528 SWE Snowblower,
Old 09-08-2011, 09:34 AM
Arrowhead's Avatar
I haven't had much time to work on it lately. I did manage to get the hitch blasted and painted.
I made the lift rod out of stainless. I still need to drill the pin hole.
The original front wheels had the valve stem on the outside. I welded that hole shut and installed them on the inside for a cleaner look.
Ed
Essex, IL.
Old 09-08-2011, 11:02 AM
Very nice!
Old 09-08-2011, 11:29 AM
ajcombs's Avatar
ajcombs ajcombs is offline
Looks great keep those pics coming cant wait to see an entire tractor pic when finished!!
