Old 07-08-2011, 03:43 PM
msobie64 msobie64 is offline
Does anyone know if the 128 has adjustments for cutting height?
Old 07-11-2011, 11:25 AM
Hey guys, I finally got back to the barn and pulled out the tractor. The old Kholer started up after I "cleaned the carb" float was stuck open. Ran rather well with some new gas and an oil change. Looks like I need two new front tires (size ? or recommendations?). I also pulled the deck off, seems to be 42inch with no guide wheels, that normal? All spindles and blades spin freely and little to no through rust, looks to be all surface (overall I'm pretty happy so far).
Old 07-11-2011, 12:08 PM
Good Looking 128. As for the front tires, if you have the narrow rims most people here like the Deestone Tri Ribs. 4.00x8. The deck is normal. Gauge wheels were an option that you could add by welding on the brackets and installing the wheels.
tires:
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
Old 07-11-2011, 12:22 PM
Thanks for the link, the current tire on the tractor is "Goodyear Highlander GT" 4.8-8. I'm assuming the rim is 3.75" or 4" wide.
Old 07-11-2011, 12:28 PM
Yeah. You definitely have the narrow rim. My preference.
Old 07-11-2011, 12:31 PM
Is there a how-to for mounting your own tires? Or would I have to take them to shop?
Old 07-11-2011, 01:39 PM
Nice looking 128!
Old 07-11-2011, 03:14 PM
You might google 'changing tire'.
And also look on you tube.
Old 07-11-2011, 05:41 PM
MrGitrdone41's Avatar
Your 128 is made in 1971. I can tell by there is no 3 holes on the left side of the frame.
1988 1812,dual ports
1973 108
1968 125
Old 07-12-2011, 11:16 PM
Is it ok to wash the tractor if I disconnect the battery? Anything I Need to be careful of?
