Old 06-27-2011, 10:21 AM
Psevins Psevins is offline
Default Blade questions
Hello. Been looking through past posts on blade installation but i need some clarifications. I have a 102 with deck and a blade. Ive never installed the blade so this is a new endeavor. Ive read a lot about nf blades both qa and bolt on. Ill post my pics this evening after work but the blade subframe has two pins pointed inward that look like they should rest inside a bracket. My front end has no such reciever (holes yes. But nothing that the pins can make it into) im thinking i need a bracket or i have the wrong blade. Like i said, ill be posting pics this evening. Thanks, Corey
Old 06-27-2011, 10:27 AM
Corey when you say blades do you mean deck? I don't think the 102 has the QA feature. My 122 didn't have you checked out the oper manual in the tech section of the site yet?
Old 06-27-2011, 11:12 AM
Sorry. Yea blade, snow blade. Mower deck but i did drop that yesterday. The frame is still on so i will need to remove that too
Old 06-27-2011, 11:41 AM
I did check that out but was still not clear on how things go togethet
Old 06-27-2011, 11:46 AM
Check this link out and see if it helps:
http://ccmanuals.info/pdf/Front%2042...l%20Manual.pdf
Old 06-27-2011, 01:10 PM
Aha. I have that pdf but mine is apparently missing a few pages!
It looks to me then that the blade i have isnt meant for my tractor. Mine is a narrow frame blade but it is for the quick attach setup. So my question would be could i replicate the qa bracket or remove the qa pins from the blade frame and mount it accordingly?
Old 06-27-2011, 07:35 PM
CaptMax's Avatar
CaptMax CaptMax is offline
I had the same issue on my 102 and just left the pins (No QA attach here) and mounted it as in the manuals. It fits just fine.
CaptMax
Old 06-27-2011, 10:19 PM
It all depends on your subframe for your blade. I have seen some subframes that have the QA pins on them and holes for mounting and I have seen some subframes that only have the QA pins on them (though this may have been a PO mod...) and some that only have the holes in them. If your subframe has holes above the QA pins, then you can attach it and ignore the pins and it should fit, if it only has the pins, then you can drill holes or weld on the QA brackets---which would allow you to use other QA implements in the future as well.
Old 06-28-2011, 08:16 AM
There are some additional brackets that are used to put a QA blade on a tractor with no QA. Unfortunately I don't have a picture but they are just 3/8" x 1" or so pieces of steel about 6" long with 3 holes in them. Make those before you go hacking up your blade and/or tractor. Anybody know what I'm talking about and have a pic?
Old 06-28-2011, 08:28 AM
These are what you need.There are 2 of them.
Up to 534 and counting...
