Old 06-26-2011, 12:23 PM
Originally Posted by Darrell View Post
Try wiggling the plug on the back of the key switch. I have a 1450 that sometimes has no fire and the plug is corroded. I took it apart and cleaned it , and it is better , but i need to replace the switch and the plug.
All good ideas, I replaced the ignition switch, it was shot. When I got it home it wouldn't turn over, found the switch was bad, as I had it apart I cleaned up the plug, so I'm thinking that's not it.
I've got power to the points, just checked that, could it be the points?
Old 06-26-2011, 12:57 PM
Originally Posted by Wild Bill View Post
Todd: How are you checking for spark...are you letting the spark plug sit on the head, and watching it while you crank the engine? Is the coil you installed from a different tractor known to be 'good'?
The factory Quietline engine ground 'strap' is a short yellow wire coming from between the right side firewall bolt and the frame (the terminal is sandwiched between the bottom of the sheetmetal firewall and the 'spud' on the frame for the firewall's attachment bolt)-to one of the regulator/rectifier bolts >or one of the bolts that hold the flywheel shroud on...I've seen them in both places.
It is possible for the engine to find a ground through the throttle and choke cables (if the short yellow wire is missing) . This causes intermittent electrical gremlins, and most times the throttle and choke cables will get wickedly HOT!!
Hey Bill, checked everything as you mentioned, parts are from my 122 that work fine. I checked for power with test light at the points wit hswitch on. I don't have a meter to use, just a light.
I also don't see any ground strap what so ever, think I should fab one up? Just to safe.
The points are the one's that were in the tractor when I brought it home, I did use some sand paper on them, to clean em' up.
I'm going out to cut the lawn and cool off, this thing is driving me crazy, and God knows it wouldn't be a real far trip
Thanks, I'll check back in about two hours, by then you all should have it figured out
Old 06-26-2011, 05:44 PM
Default 1250 LIVES again thanks to you
Well it runs, not real pretty, but it runs.
Found where the ground wire should have been, the PO must have needed a short wire for something and removed it
Made up a new one and cleaned up the attachment points and away it went, so to speak.
Well I sure do appriciate everyone chimming in with your suggestions, really helped alot.
If I wasn't so far away, the cold ones would be on me
Thanks again!!!
Old 06-26-2011, 06:03 PM
That's awesome, Todd!
Old 06-26-2011, 07:10 PM
Amazing how a tiny little ground wire can throw a monkey wrench into the whole works and drive you crazy, LOL. I am glad to hear it is now making some noise.
Old 06-26-2011, 08:55 PM
william1041200's Avatar
Thats great!
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 06-26-2011, 10:09 PM
Yup, that's for sure. It not only makes noise, it blows smoke pretty good to
Old 06-26-2011, 10:11 PM
juniors1282's Avatar
Congrats Todd. Good thing you made that addition so big, hehehe.
1966 IH cub cadet 102x2
Old 06-26-2011, 11:02 PM
Feels good to get it running,now you can go for a drive...
Old 06-27-2011, 12:33 AM
Glad ya got another one running Todd!
