Old 06-13-2011, 01:22 AM
hilltop's Avatar
hilltop hilltop is offline
Default Are all NF clutches the same?
My 104 is in real need of a new clutch and I just saw an ad for a NF clutch but he doesn't list a model number - are all NF's the same?
By the pics it looks pretty good but being a rookie I can't be sure.
Could you guys take a look and give me your opinion?
Thanks!
Neil
http://portland.craigslist.org/clk/grd/2431126589.html
Old 06-13-2011, 06:14 AM
Thanks!
Neil
Yes that will work. It looks short I wonder if it was in a tractor that had a creeper gear in it. Great price too!
Old 06-13-2011, 09:11 AM
If you need a new clutch, I would get a new one, not a used one. There's nothing guaranteeing that one is any better than the one you have, or that it'll last if it is. You can have the pressure plates turned on a lathe, and buy a new pilot bushing, friction disc, teaser spring, throwout bearing, main spring, new spirol pins, and make a driveshaft, and you won't have to worry about it for another 30 years or so. It'll cost about $150 but it is money well spent.
Old 06-13-2011, 10:27 AM
hilltop's Avatar
Duke,
My 104 has a creeper so if it's short for that reason I'm good to go.
Matt,
Actually, 2 dinner plates with a piece of plywood between would be an improvement over what I have now - but I hear ya - new is always better. But for 20 bucks this may be good for a short fix and it's local - I'm just trying to get through this mowing season - I've got to pull the motor this winter and do a bunch of frame work, replace the head gasket and it's wanting rings so I'll probably rebuild it and do a whole new clutch assembly then.
Thanks guys!
Old 06-13-2011, 10:40 AM
Soaper Soaper is offline
not trying to thread jack... lol
but im still trying to figure out on how to replace the clutch...
mines a slipping.
i like the plate comment though. haha
Old 06-13-2011, 11:20 AM
hilltop's Avatar
Hey Soaper,
I'll be doing a site search here shortly (I'm sure somebody has posted the procedure somewhere) when I find something I'll post the link.
Yeah, my current clutch is in bad shape - the holes on the friction disk have egged out real bad, the teaser spring is in sorry shape, I had to do a weld rebuild of the hole for the pivot pin on the clutch arm and I just discovered the v-belt pulley that the three pin plate is attached to is missing a big chunk - all that adds up to some vibration that's not doing my 104 any favors.
Old 06-13-2011, 12:26 PM
hilltop's Avatar
Soaper,
Go to the technical library for tractor here on the site and find the "Manual - Service Chassis" for your model number.
For my 104 - Clutch removal and reassembly starts on 2-14 (Page 56 of the pdf file).
I found all sorts of other posts regarding tricks and tips for doing this.
I searched for: NF clutch removal
Do some poking around and if you get stumped don't hesitate to ask the guys here ( I know I will once I get into it ) - they're great about lending a hand!
