Old 05-27-2011, 07:48 AM
nycub122 nycub122 is offline
Default K301 Flywheel Removal
How do you hold the K301 flywheel to loosen/tighten the flywheel nut? I know that the Service Manual says to use a strap wrench, but I don't believe that is possible, since the blower housing and grass screen/drive pulley are installed before the flywheel nut is installed.
Any ideas?
Thanks
GEL
Old 05-27-2011, 07:54 AM
steveyrock's Avatar
steveyrock steveyrock is offline
I use an air gun to remove the nut,no need to hold the flywheel.Try a sharp blow on your ratchet handle to break it loose with a strap wrench on the other end of the crank.
122-snow blade and 42 deck, wheel weights, fluid filled tires,chains
106-42"deck
1250-44 and 50" decks
147-44"deck
2155-42"snowblower 38"deck, chains,suitcase weights
Exmark Quest-zero turn 42"deck 23hp Kawasaki engine
Old 05-27-2011, 09:16 AM
jmroy's Avatar
jmroy jmroy is offline
I put a strap wrench on the pto basket when I did mine.
Web Developer - Need a website? Contact me.
Old 05-27-2011, 07:59 PM
westofb's Avatar
westofb westofb is offline
Years ago I had a 102 project, I do not recommend using an air impact on the nut that holds the flywheel on. I tried this myself on that project and got to add the cost of a new crank to the build. It sheared off the entire threaded portion of the crank, back then a new crank was $160 or so, now they exceed $400.
Jeff
Brookfield, MO
________________
Old 05-27-2011, 10:44 PM
hjsmith00843 hjsmith00843 is offline
does it have a flywheel gear on it. If so use a pair of locking pliers on it. Use a harmonic balancer to remove it. You might have put pressure on it with the puller then tap it gently with a hammer. Should pop right off.
Operation Iraqi Freedom Vet!!!!
Old 05-27-2011, 11:23 PM
jmroy's Avatar
When I did it I practically had to stand on it. Some are easy, some aren't.
