Old 05-22-2011, 08:25 PM
cj4200's Avatar
cj4200 cj4200 is offline
Default 149 Will not run without charger
As title states my 149 will not stay running without the charger. I just took it out for the first time this year hooked up the charger to start it took the charger off and it dies in a couple seconds. Tried several times any suggestions?
Old 05-22-2011, 08:28 PM
Just went through this. (A) Your battery won't hold a charge, or (B) your Voltage Regulator won't charge the battery.
Update: This is assuming, that you have no electrical wiring issues of bad connections or broken wires.
Old 05-22-2011, 09:10 PM
cj4200's Avatar
Well I put a known good battery in it, the one out of the 129. it ran for awhile then she died. So tomorrow I will check the VR. Thanks for the suggestion.
