Old 03-28-2011, 01:13 PM
greg9168 greg9168 is offline
Default Need help replacing ignition module on SGT 1882
Are there any 1882 owners out there that can tell me if you have to pull the engine to get to the ignition module on this tractor? The metal shroud around the back of the engine is right up against the frame and it doesn't look like there is enough room to pull it out. Thanks for the help.
Old 03-28-2011, 02:42 PM
ajgross ajgross is offline
Inactive Member
The engine is going to have to be pulled. You have to take the flywheel shroud off and you just can't do it with it in the tractor.
AJ
