Old 03-08-2011, 09:28 AM
Mike in NC's Avatar
Mike in NC Mike in NC is offline
Default Started as replacing the fiber Button
This started as replacing the fiber button on the PTO clutch. I looked at the engine and frame and said this must be cleaned. Now waiting for a little time when it is dry outside to pressure wash this mess. I am going to put our Model 1 tiller on this tractor.
Mike Murphy Mike & Jen's Old Engines Original OCC Member #23
Cub Cadets: 102, 128(X2), Model 1 tiller, Model 1A Sweeper, QA-42A Snow blower, 38" CI end mower deck, QA 42" mower deck, Brinly cultivator, Brinly 10" plow, sleeve hitch adaptor
Old 03-08-2011, 11:47 AM
cub123's Avatar
cub123 cub123 is offline
Looks like fun,a strong PTO is a must when running a tiller.Looks like it will clean up just fine.
Old 03-08-2011, 11:53 AM
From the looks of that mess you have an oil leak.maybe behind the pto basket.Good time to do it whilest you have it apart.
Old 03-08-2011, 01:30 PM
Mike L. Mike L. is offline
I have the same job to do on my 149 . when I got the grill removed I found he pto rockshaft frozen in the bushing. took a half can of pb blaster to free it up. once I got it moving I removed shaft and wire wheeled everything , greased it now it works great.
Old 03-08-2011, 06:21 PM
Mike in NC's Avatar
The oil seal was bad, and was replaced about a year ago or so. But did not think about cleaning up the frame. It is just so nasty, it needs done. The engine block looks about the same, so I am hopeing it will help the engine cool better.
Old 03-09-2011, 01:08 AM
I would start by using some good degreaser, before pressure washing. In fact, I would NOT pressure wash the engine, just use the degreaser and maybe a spray bottle of soapy water to clean it up. You might be amazed at how that gunk just drips off with some good degreaser without a pressure washer. Can't wait to see the "after" pictures.
Old 03-14-2011, 12:01 AM
Mike in NC's Avatar
Well, it was beautiful here today, so I got the 128 out and cleaned it. Used hose on the engine, pressure washed the frame and axles.
Old 03-14-2011, 12:20 AM
Great job, Mike! Your 128 cleaned up nicely!
Old 03-14-2011, 02:13 PM
IAfarmer's Avatar
IAfarmer IAfarmer is offline
Well, if you have it that far apart, you might as well paint it.........
Old 03-14-2011, 02:43 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
True and if your gonna break out the paint you might as well do the whole frame. Just consider it a soft restore, you can have it up and running in a month or two no problem. Lol
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
