Old 02-23-2011, 10:39 PM
Sminkey
Guest
Posts: n/a
Default #30 carb throttle linkage??
Just got my #30 carb and didn't realize until I mounted it on the 147 that it has a different throttle shaft. Went and looked at the 124 and thought it was the same so I stole it temporarily only to see that the one on the #30 is pressed in, not threaded with a nut. So is there a linkage that snaps onto the ball on the #30?? The one on the 124 is all metal and I'm not messing that one up. Got it running, but will only run with a good bit of throttle, will stall right out at low idle. I do need to rebuild the carb, maybe part of the reason.
Old 02-23-2011, 10:44 PM
Here is what you need:
KH-45-208-03 $8.78
These pop on and off the ball fitting on the carb. Will thread onto your existing arm like in the pic you showed above.
Old 02-23-2011, 10:46 PM
Sminkey
Guest
Posts: n/a
KH-45-208-03 $8.78
Sweet, thanks DX3! I was being lazy and knew somebody on here had the answer.
Old 02-23-2011, 10:50 PM
It is the same style that was on my 1250 carb. Glad I could help.
