Old 08-05-2026, 12:08 PM
I have the procedure for the 1864
1 remove right foot plate.
remove hydraulic cylinder,
remove/replace rock shaft.
reassemble.
thats it.
Not sure if the shaft will work in a 782 as it is a whole different setup.
Up to 534 and counting...
Old 08-05-2026, 01:29 PM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
Originally Posted by Frank1541 View Post
Did you remove parts 9 and 10 from 8? That could buy you another eighth of an inch.
I know it can be done, because I installed one on them 1541 when I converted it to an 1864. The trouble is a did this 15 years ago, so I don't remember how I did it. You may have to remove the drive shaft.
Spreading the frame rails is a bad idea in my mind, unless you only need a small amount of room to do the job.
I only need like 1/16" more clearance to get it out. I might actually just pull the deck lift arms in a little bit to get just enough clearance to get it free.
I have literally everything removed in that area, the tractor is just a bare frame with a dash and the rockshaft on it. The rockshaft is the last thing I want to remove before the rest goes in the scrap pile.
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
Old 08-05-2026, 07:29 PM
Grandpa53 Grandpa53 is offline
Can you post a pic of the shaft showing what you have removed?
Old 08-05-2026, 11:38 PM
Mudrig150's Avatar
Got it out... You have to turn part #8 toward the back of the tractor and then rotate the whole rockshaft as far back as possible and then lift it out of the top of the frame. It doesn't have enough clearance to go out the bottom and barely clears the top of the frame rails.
Old 08-06-2026, 09:42 AM
ironman's Avatar
ironman ironman is offline
If I could kick myself in the balls, I would, for wasting the few precious moments of life that I have left reading about your foibles on how to remove a rockshaft.
Old 08-06-2026, 02:31 PM
