Old 06-19-2026, 10:17 PM
Chevyboy89 Chevyboy89 is offline
Yes the pump seems to be working, the engine will skip a little, the rpms will drop and then it shuts off like I hit the fuel shutoff. I'm definitely leaning towards a fuel delivery issue. The machine has 630 hours and I'm hopeful it's something small.
Old 06-20-2026, 11:18 AM
First thing I'd do is get that semi truck exhaust pipe off of it, otherwise you will be buying an exhaust manifold, because it broke, if it has not already happened.
On a good note at least that can be purchased, unlike Tinnitus that there is no cure for, or inhaling diesel particulate.
Old 06-20-2026, 12:40 PM
I got rid of that ridiculous thing this morning, unfortunately all I had laying around in the barn was a muffler from our 8n field decoration hahaha. On a better note, it ran so much better with the muffler installed, it finally did die after it stumbled several times. I decided to pull the shutoff and check the screen, it was completely plugged so I removed it and reinstalled as a test, it hasn't had a single hiccup with me pushing it's guts out. So I will be cleaning the tank and changing the filters and start running treated fuel
Old 06-21-2026, 07:55 PM
Sounds like a great plan.
Old 06-21-2026, 08:13 PM
Treated fuel????
Wast of your $$
Old 06-21-2026, 09:08 PM
I will run an algae prevention treated fuel. I run anti gel in my pick up and will run it in the cub when the weather turns cold. So far it's running pretty good, I have figured out it will need a starter as it has one start in it when the engine is warm.
Old 06-22-2026, 09:18 PM
Happy to say it's running good, but I have to find a new exhaust, preferably factory as my homemade replacement isn't cutting it.
Old 06-23-2026, 05:57 AM
Here ya go. This is a good deal too.
https://www.onlycubcadets.net/forum/...ad.php?t=61474
Old 06-23-2026, 06:04 PM
I appreciate the link, it's just outside of my budget at the moment. I'd definitely settle for a good used one if possible.
