I have a M18 Kohler from an 1810 (if I remember correctly used oncustom build). Anyway I just replaced the ignition coil and it runs great. The problem now is the PTO runs all the time and makes a squealing noise. It won’t shut off. I even unplugged it and it still runs. I’m assuming the bearings are bad. I never use it and never will so my question is , is it ok to remove it and leave it off?
Chip T. Drexel NC |
No problem to remove it, if you don't use it.
And you are right that the bearing is bad. Hang on to the pto, it can easily be fixed with a new $10.00 bearing.
