Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Rear Engine Rider & ZTR (RER)
Old 08-11-2025, 01:46 PM
Gremilin Gremilin is offline
Default CC-30 H Forward and Reverse pedal has no resistance
I have a CC-30 H Model #13A221JD010.
The forward and reverse pedal has no resistance. When sitting, with engine running, it falls to forward and takes off. I have called customer service a number of times with no help and I have also called 36 Cub service centers with no help. None of them can figure it out, I would think there would be maybe a spring or ball plunger to at least indicate neutral. We are all looking at the same diagram.
I would appreciate any and all help!
Thanks
Old 08-11-2025, 03:24 PM
ironman's Avatar
ironman ironman is offline
I'm not familiar with your model but it looks like spring (#15) connects from frame
to that small hole in idler arm (#2). Spring may have broken or become disconnected.
That's where I'd start looking.
Old 08-11-2025, 05:22 PM
Thanks for the input the spring is in place I don't see where that has anything to do with the forward and reverse pedal assy
Cub Cadet CC 30 H (13B721JD056) - Cub Cadet Hydro Mini Rider (2018) Pedals Parts Lookup with Dia.jpg
Old 08-11-2025, 06:45 PM
ironman's Avatar
Just a guess, since it has the motion drive belt pulley's on the idler arm I figured it moves when you move the pedal and the spring would provide the tension.
But moving right along, here's another guess....
Check the return to neutral spring on your hydro, p/n 167.
Old 08-11-2025, 08:03 PM
Thanks again The spring is there and in the right place
Old 08-12-2025, 03:56 PM
I have a hard time believing that Cub can't solve this problem It shouldn't be this difficult
