Old 01-08-2011, 08:00 PM
Default Hand clutch on the 100
Well I finished the hand clutch today. It wasn't all that hard either.
The angle iron mounted to the floorboard was drilled and mounted using the holes in the floorboard as guides, and bolted with 3/16 bolts, without having to alter the factory boards.
The handle is from an old ATV snowplow, so that cut time not having to make one. The rod between the handle and clutch was cut to length, and then I put it in the wood stove to heat it up enough to bend the ends.
Drilled the ends and added pins, good to go! The one picture before the rod was painted is with the handle in the brake position.
Was a fun project, now looking forward to a test drive.
Old 01-08-2011, 08:58 PM
steve59's Avatar
steve59 steve59 is offline
Zippy, That is SO Cool!!!! Please post some pictures with you and it in action!! I've done a lot of modifications on farm tractors and combines for farmers who are handicapped too. NICE JOB!!!
Old 01-08-2011, 09:41 PM
hilltop's Avatar
hilltop hilltop is offline
As a blacksmith, that's the kinda thing I like to hear!!
Great job Zippy - Ditto to Steve, action pics please!
Old 01-08-2011, 10:13 PM
Sminkey
Guest
Posts: n/a
Very nice work Zippy. Looks like a nice 100 ya got there too!
Old 01-08-2011, 10:29 PM
Thanks for the kind words.
It will be a bit before the test drive, I need to find me a seat with some cushion or I'll have a sore on my this one that came with it is not something I care to put some seat time on!
So now I'm looking for a seat with some softness
Old 01-08-2011, 10:37 PM
Very good! The fact that you made it go over center will keep the pedal up and prevent the clutch from getting disengaged partially from the handle bouncing around. That'll keep you from having clutch issues like I warned about in your other thread. As long as the lever stays put while you are driving, you shouldn't need a stronger clutch return spring.
Old 01-08-2011, 10:48 PM
Matt, I did put one on per your suggestion. And I just don't want the handle flopping back and forth, but I also have the spring on the handle pretty snug, so it seems to be steady.
Old 01-08-2011, 11:28 PM
ihnick's Avatar
ihnick ihnick is offline
That's sweet. My old 100 came with a half a$$ hand clutch. Notnear as nice as that
Nick.
Old 01-09-2011, 01:57 AM
Great job, Zippy! I like that!
Old 01-09-2011, 11:04 AM
jeffscub's Avatar
jeffscub jeffscub is offline
and as a fan of blacksmiths, i could sit and watch someone do that all day long. it's one thing to have the satisfaction of building something with your hands but it's even more when you actually forge something with your bare hands!!!!! jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
