Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 05-26-2024, 11:43 AM
rdm522 rdm522 is offline
Default D600 Operating Temperature
My 782d seems to be running hot to the touch. What temperature should the engine be running at? I run the engine about 30 minutes and the oil cap is so hot to touch. Is this normal? If not, what should I be looking at diagnosing?
Old 05-26-2024, 12:55 PM
CubDieselFan's Avatar
Does the gauge still work? Is the insulation still on the top hose that goes to the radiator?
It is going to get pretty hot under the hood.
Old 05-26-2024, 01:05 PM
I’ll have to test the meter. It does still have the insulation on the top hose. However, it is somewhat weathered from age.
Old 05-26-2024, 01:08 PM
I am going to cut the grass with m 1572 this afternoon. I will take some pictures of the gauge after 30 minutes of run time. Good comparison test.
Old 05-27-2024, 09:22 AM
What is your gauge reading? I think anything over 140* will feel hot to the touch. Here's what the decal says under the hood. " Anything under 230* is normal". I don't think mine ever get above 170*.
Old 05-27-2024, 02:38 PM
This is after 10 minutes of run time.
Old 05-27-2024, 02:42 PM
After 30 minutes of working the mower pretty good. I stopped to see how hot the oil cap was and you could hold it 2-3 seconds. I let it run for a couple of minutes with no load and it cooled down fast. I mowed a little slower in the tall grass and it did not get as hot.
Old 05-27-2024, 02:45 PM
I do this to all my diesels and it helps. The crossover hose will pick up heat from the engine. Might be overkill but only takes a few minutes to do.
Old 05-30-2024, 11:13 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
My 782D has a 180 degree thermostat. It has all new coolant and belts. It likes to run 190 degrees on hot days while mowing. The OE gauge has been replaced with a mechanical numerical gauge for better temperature accuracy.
