Old 02-26-2024, 08:22 AM
ironman's Avatar
ironman ironman is offline
I thought I saw a puddy cat...
I know the threads do not go all the way to the top so crud will accumulate, try stuffing tin foil in the hole.
FWIW:
My experience with Settin' screws is they are hardened.
AND if they protrude out of the thread and are tight/rusted when one tries to loosen them, the hex will split open, and that is not a good thing.
And Stainless while rust resistant, is softer metal so the hex swells and strips.
Your mileage may vary.
All good points I hadn't considered. I'll rethink about this, thanks.
Old 02-26-2024, 11:00 AM
Ambush Ambush is offline
Whenever you have a tough to turn set screw that protrudes, thread a nut on flush with the end. That keeps it from splitting. Also use a pin punch that fits into the wrench hole and give it a few dozen sharp raps with a hammer. That relieves pressure on the end of the screw and on the threads, to ease turning.
Old 02-26-2024, 11:20 AM
ironman's Avatar
Wow, another great suggestion.
This thread has turned to be really informative (at least to me).
Thanks to all.
Old 03-01-2024, 03:02 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Whacking the bottom of the hex screw "socket" with a thin pin punch with some penetrating oil before and after , has always done the trick for me. Repeat as required. If the screw begins to turn then binds up again, don't force it, thread it back IN again, flood with penetrating oil and repeat back and forth until it comes all the way out.
Make sure the pin punch is at the BOTTOM of the hex "inlet" of the set screw!
Also: Use good quality US made Allen wrenches, not your Harbor Freight specials!
Also: Considering goobering some grease in the hole after you put it back together , to slow down the rust process. The next owner will sing praises in your name.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Tags
clutch, screws
