Old 01-11-2024, 06:55 PM
pepperpikker pepperpikker is offline
Default Retrofit an electric PTO from LT1045 to LTX1045
I have an LTX1045 and want to put an electric PTO on it. It currently has the manual lever. Can I grab an electric PTO off a LT1045 and put it on the LTX1045 and wire in a switch for it? Is it possible? Is it pretty simple?
Old 01-11-2024, 07:20 PM
Farmall450's Avatar
I would check into needing to change the deck drive belt too, and possibly some safety sensors from the (manual) PTO lever. You may also not have a strong enough charging system to handle it.
You could compare cranks from both to be certain if you already have the LTX1045 handy and/or review the parts diagrams on CC's site.
Old 01-16-2024, 05:34 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
If the LTX1045 has a stack pulley on it you would need to find a transmission drive pulley to go above the Electric PTO. Unless the one on the LT1045 will work.
Cannon
Old 01-16-2024, 10:19 AM
OK, thanks everyone. You all confirmed that it isn't just a simple swap and will pass on the project.
