Actually its a 1512 (=782D, 882). PTO switched off while mowing and wouldn't reengage. Ran fine otherwise. After parking it and letting it sit for a few weeks, just went out to restart and have no power whatsoever. When trying to warm up glow plugs I get nothing - no fuel pump, oil pressure light or glow plug indicator. Topped off battery and tried jumping from truck but still no juice at all.
The ignition switch was replaced with OEM earlier this summer. Connections all look good - its always been garaged. Figured bad PTO switch shouldn't effect warm-up and starting circuits. Would brake switch do that? Looks like PO bent the reverse cutout switch contact so reverse lever doesn't activate it. Circuit breaker? Voltage regulator? Thanks for any suggestions! |
Circuit breaker is more like a fuse on these. See if there's power at the key switch, then see where it stops. I'm guessing there isn't and the fuse in the dash let loose. Is there power to the amp gauge?
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
A little more info: just checked the PTO and the gaps are a bit over spec. Wondering if the increased current needed to engage the PTO tripped the breaker? If that happened the engine would have continued running until I shut it off, correct?
There was nothing showing on ammeter when I tried the glow plugs or tried cranking, so I suspect you're right. Won't be able to get back to check current for a couple of days. I might try bypassing the breaker to verify.
My 1572 did a similar thing. It was corrosion on the studs of the breaker. The battery lives above a lot of electrical components so it only a matter of time before the corrosion finds its way to a connection.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
Check the fuses. I had a similar issue and found the fuse was fine looking thru the glass but was bad when I checked it with a multi-meter.
Went to replace the ~37 yr old circuit breaker and found one of the nuts was loose. Pulled the wires and clamped them together and viola! - I had power again! Guessing that caused the PTO to cut out and everything else is fine, but its dark now so I'll fire it up tomorrow to confirm. I love it when problems have simple fixes. At least I'll have a new circuit breaker, properly adjusted PTO gap and increased knowledge of how this machine works! Thanks for all the tips.
