Old 08-23-2023, 12:10 AM
TheSaturnV's Avatar
Default 421 U 1113: Source for oil seals?
Hello all, finally getting around to restoring the deck for my 147. I did search, hopefully I was thorough enough. Does anyone have a source for the oil seals (6 required)? NAPA lists one as industrial non vehicle specific, but maybe someone has found a better option under a different PN that is more easily available over the counter and cheaper?
The PN I am working from is 530484 which doesn't lead to anything on RockAuto.
Thanks.
Edit: Went through the NAPA checkout page and they want me to pop for $20 shipping, so $50 bills for 2 seals........
Old 08-23-2023, 03:47 AM
Masamla Masamla is offline
I ordered the 6 oil seals for my 421u1113 right from a local Cub cadet dealer that was less than a 3 minute drive away. They still sell the seals, part was IH-473428-r92 my local dealer charged me $13.99 each. One thing I’m not 100% on tho is if the 2 possible spindle styles use the same oil seals? Mine have replaceable oil seals and bearings.
Old 08-23-2023, 04:02 AM
Picture of the seal and the bag it came in
Old 08-23-2023, 05:22 AM
TheSaturnV's Avatar
Ok, thanks for that info. Luckily on two of the 3 spindles the seals feel like brand new so I'm just rebuilding one. Also glad this deck has the relatively cheap automotive type bearings/races.
Old 08-23-2023, 10:31 PM
athomas's Avatar
athomas athomas is offline
My local napa dealer, free shipping !
This item is not vehicle specific.
Oil Seal - Industrial
Part #: NOS 530484
Line: NAPA Oil Seals
Price
$9.33
NAPA
Seal I.D. 1 in.
VMRS Code 065004020
Seal O.D. 1.785 in.
Width .25 in
Old 08-24-2023, 11:54 AM
Part #: NOS 530484
Price
$9.33
NAPA
Seal I.D. 1 in.
VMRS Code 065004020
Seal O.D. 1.785 in.
Width .25 in
That is where I get mine also.
Old 08-24-2023, 12:12 PM
Graflex45's Avatar
Graflex45 Graflex45 is offline
your lucky with those, i tried to go to napa to get new seals for my 70's deck and the 3/4 in seals i needed would have to came from 6 different stores and they wanted to charge me $20 shipping for each piece
As an aside do you need new shaft spacers that the seal rides against? I found an ebay seller that has stainless steel ones that I'm replacing the pitted and worn ones with. they even did a custom size for the ones I needed
1450- 44A deck,QA-36 snowthrower, 42in front blade No.2 Tiller
70- 38in deck, 42 inch deck
Old 08-24-2023, 05:00 PM
TheSaturnV's Avatar
Thanks for the NAPA info. The main local NAPA distribution hub is not far from me and they don't even list the NOS 530484. I found an industrial supply source online at around $8 each. The order is still pending, we'll see if it actually ships.
Old 08-25-2023, 09:46 AM
jcubtroy's Avatar
jcubtroy jcubtroy is offline
I found that some NAPA stores wanna deal with only car stuff no small engine ,or tractor stuff. but other NAPA,s do. Depends i guess who works there.
Old 08-25-2023, 11:21 AM
Graflex45's Avatar
Oh I totally spaced, the shaft is 3/4 but the spacers bring it up to 1 inch so thats probably the same seal i needed. I had a mix of the original IH marked part numbers and skf seals on the 2 decks
