Old 08-08-2021, 09:10 AM
Yeah, and it will probably last about 25 minutes.
Old 06-19-2023, 10:22 AM
Waltman1201 Waltman1201 is offline
Default 304 Tiller Manual
Where can I find a manual for my 192-304-100 tiller, and any ideas on parts some are hard to find.
Old 06-19-2023, 11:33 AM
Sergeant's Avatar
Sergeant Sergeant is online now
You can find the manual here: http://manuals.mtdproducts.com/mtd/Public.do
for Model Number: Use 1903 don't use the full model number as the search will not find it.
For serial numbers, use 8 numbers, like 11111111
Scroll down till you find 190304100 it will be Manual 772-9033a when downloaded.
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force
Old 06-19-2023, 12:01 PM
Looks like it's only 28" wide!
Old 06-19-2023, 08:33 PM
Sergeant's Avatar
The hydraulic tiller that replaced it was only 30-inch I had either option when I bought my 2206, and I went with the 30-inch Hydraulic which MTD had just introduced at the time. The 30 utilized the sleeve hitch frame, while the 28-inch used a frame that slid into the frame rails. I think the 28-inch design would actually fit on the Late 2000 and XT3 series due to its rail-mount design. I actually like smaller tractor-mounted tillers myself because you can do some nice cultivating with them if you space your rows right.
Old 06-20-2023, 07:31 AM
304 28" Rear Tiller 190-304-100
The parts lookup comes right up when I enter the number on the CCC site
https://www.cubcadet.com/en_US/conte...rtstream.html#
Old 06-20-2023, 08:45 AM
ironman's Avatar
ironman ironman is offline
From his original post....
"but I can’t find anything about it online other than parts diagrams. No actual pictures of it or how it mounts/works with the tractor. Does anyone know anything about it or have pictures of how it mounts and gets power, as these tractors only have front PTO, not rear?"
So, click this link....
https://www.ccpartsnmore.com/cub-cadet-service-manuals
Scroll down to CUB Cadet Series 2000 Service Manuals....
Click the left block (1994 to 1999)
View Section 7-5....28 inch rear mounted tiller (190-304)
Old 06-20-2023, 11:26 AM
Sergeant's Avatar
The Manual for the tiller show how it Mount to the Tractor But here what it Looks Like Mounted with electric actuator
https://www.youtube.com/watch?v=Jd787rxLajk
Belt run from Front PTO under tractor to Tiller In rear almost Like the Old IH 1 or 2 Tillers The tiller Mounts In the Tractor frame Just Like the Rear/Front weight bracket Mounts
