Old 05-23-2023, 06:43 PM
Jim in SC's Avatar
Jim in SC Jim in SC is offline
Default Need some help with rear axle bearing
I'm working on refreshing my Original and pulled the left rear axle so I could check the brake. All is good there except an oil leak which is an easy fix. While I'm in there I need to replace the bearing. Here's my problem - I can't get the cage out. Does anyone have a recommendation how to get it loose? Here's a picture:
Oh, yeah - I did remove the bolts and the oil seal.
1951 Farmall H; 1957 Willys CJ5; 1959 Farmall Cub; 1961 Cub Cadet Original; 1963 & 1964 Cub Cadet 100's; 1971 Cub Cadet 106
Old 05-27-2023, 10:25 PM
dale c. dale c. is offline
That is the side bearing cap. You have to take the three bolts out then it should come out. You need to remove the back cover and the other axle housing to remove the ring gear housing assy.
Old 05-28-2023, 04:44 PM
Jim in SC's Avatar
Nope. I did remove the three bolts and it won't budge. I can "spin" it using a drift pin and a BFH, but it won't "just come out". Kind of weird 'cause it's the same set up on my Farmall Cub, which did come right out. I was wondering if it might require a puller of some sort.
Old 05-28-2023, 07:34 PM
You can use a puller, but not sure what your are going to grab. there is an o ring that goes around the side bearing cap on a Original that may be making it harder to remove.
Old 05-29-2023, 11:59 AM
Jim in SC's Avatar
I was wondering the same about the O ring binding up. And also what the puller would grab. Guess I'll stare at it some more. Thanks!
Old 05-30-2023, 11:26 PM
Farmall450's Avatar
Do you have a picture of what you're stuck on?
Welding around the race comes to mind.
