Old 04-14-2023, 07:14 PM
Jim in SC's Avatar
Jim in SC Jim in SC is offline
Default Need help with K161
This is a new to me K161S engine. The engine was not running when I got it and it had a bad oil seal on the flywheel side, which I replaced. After replacing the seal I buttoned up the engine and was going to replace the points. When I went to install the points plunger, it goes in fine, but it will not go in far enough to allow the points assembly to be installed. I watched it as it rides the cam and it goes through the open and close cycle fine, the plunger just appears to be too long. I cannot see that anything is out of whack with the cam or inside the block. This is my first 7 HP Kohler - does it require a shorter points plunger than a K241? here's a couple of pictures
1951 Farmall H; 1957 Willys CJ5; 1959 Farmall Cub; 1961 Cub Cadet Original; 1963 & 1964 Cub Cadet 100's; 1971 Cub Cadet 106
Old 04-14-2023, 07:28 PM
ironman's Avatar
ironman ironman is online now
Originally Posted by Jim in SC View Post
This is a new to me K161S engine .......This is my first 7 HP Kohler - does it require a shorter points plunger than a K241?
I'm old, please explain????
Old 04-14-2023, 08:23 PM
It uses a shorter plunger.
Up to 530 and counting...
Old 04-15-2023, 06:09 AM
Jim in SC's Avatar
Well that explains that . It had me stumped. Do you happen to know the length off hand? I have a couple of the longer ones I could cut down.
Old 04-15-2023, 06:12 AM
Jim in SC's Avatar
I feel your pain, but old is good considering the alternative. Darkminion solved this one for me. Now to find one of the shorter plungers!
Old 04-15-2023, 09:25 AM
Kohler 41 411 01.
Old 04-15-2023, 08:32 PM
Jim in SC's Avatar
