Old 04-10-2023, 11:51 PM
Farmall450's Avatar
Default Cat 0 - 3 Point (Agri-Fab???) Plug Aerator
I finally found an attachment I've been searching for (albeit only about 40"): a CAT 0/1 plug aerator. I suspect it's an Agri-Fab, but the ID tag has lost all markings.
Any guesses of the P/N? The only one I see a manual for on their site looks considerably different. Either way, for $20, I can't complain. Slapped 2 tubes in after work today and straightened out the tweaked knives.
Old 04-11-2023, 10:21 PM
Farmall450's Avatar
I just need to find an OEM top link or fabricobble an adapter to fit the 5/8" generic ones and I should be set to put this to work.
Old 04-16-2023, 10:51 AM
Farmall450's Avatar
Worked pretty good today. It's a bit dicey not getting the 3pt to put down pressure on it (it'll pick the rear end right up).
