Old 09-06-2022, 10:43 PM
Radioguy41's Avatar
Radioguy41 Radioguy41 is offline
Yep, piston ring groove cleaner. It's funny when you find stuff like this at a flea market or yardsale and the guy selling it doesn't even know what it is.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
1993 Craftsman LT4000
Old 09-07-2022, 10:17 PM
Farmall450's Avatar
It was time to get these after my dad's Cornwell has saved my rear more than once.
https://www.amazon.com/Lang-Tools-52.../dp/B007TX0HS6
(FYI, Lang is the OEM for Cornwell).
Old 09-07-2022, 10:42 PM
Now those are intriguing. Have never seen them before. My list sure gets
long.
Ken
Old 09-08-2022, 09:35 PM
Farmall450's Avatar
long.
Ken
Good in situations you'd otherwise have to take off other parts to get to the screws.
Old 11-21-2022, 02:41 PM
LAWN BOY's Avatar
LAWN BOY LAWN BOY is offline
Default Cub Cadet WST 100
I got a Cub Cadet WST 100 brand new. The WST 100 is Cub Cadet’s wheeled string trimmer. It always starts 1st or 2nd pull and it has really cool looking black wheels. It has worked great for my trails in the woods and other overgrown grass. I would definitely recommend the product!
Old 12-10-2022, 06:47 PM
steelsmith steelsmith is offline
Default new granite surface plate
I was looking for a thick piece of glass to use as I surface plate, but I ended up with a piece of granite counter top sample that is 1-1/2"X12"X18" for less then $20.00 .
I can stand it upon end on my tool box bench in back of my box and it's safe and out on the way, don't need help to get it out to use and it doesn't move around when I use it.
So if you want / need a good surface plate keep an eye out , the place I got mine from had over 15 pieces for sale .
Now if I can come across some bigger wet/dry sheets I will be good to go.
Old 12-12-2022, 08:21 PM
Radioguy41's Avatar
For you guys that have Hydros that you can't move without the engine running you could get a pair of these. I've used them several times under the rear wheels to move a tractor around the shop. Got them at Harbor Freight.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
Old 12-12-2022, 09:04 PM
Farmall450's Avatar
Floor jack works good, too.
Old 12-12-2022, 11:54 PM
Ambush Ambush is offline
These are commonly called engine degreasers. I recently bought a cheap one for the garage to clean up the hard to reach places in the partially disassembled 149. They do need a decent compressor, but they will spray pretty much any liquid, from soap to solvent. This one has a mixture adjustment but lacks the thumb shutoff for fluid that the expensive ones have.
They are great for where a pressure washer is just way too much. Put some hot degreaser in a bucket and you can do a very controlled clean up pretty quick.
File Type: jpg C8B803A8-82C4-4CC8-BCDD-338A41D49D35.jpg (22.5 KB, 69 views)
Old 12-14-2022, 08:32 AM
hugo454's Avatar
hugo454 hugo454 is offline
Default tap & die
I bought SAE & Metric tap and die set. I needed it for a Predator engine swap I am doing, and figured it would be best to have the complete set. Good to have and can clean up threads, if need be too.
