I need to know the spacing between the frame rails NF vs WF. I have, I believe all the parts to a rear lift hitch including the Frankenstein bolts, lift bar, and various other parts. I'm not for sure which frame it fits. The heavy casting that the Frankenstein bolts go into that lifts is about 9 inches long. Any help would be appreciated, I want to sell it.
What model of Cub Cadet tractor are you referencing??
Sounds like the OP doesn't know, and is trying to figure out what tractors the parts he has will fit.
I'll try to remember to measure a wide frame one today.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
Wide frame, narrow frame makes no difference, same inside width at the rear,
What we need are a few pictures. That will tell what model it fits then. If it is indeed about 9" long and includes Franks bolts, then it is more than likely for an early wide frame Cub. The narrow frame cubs used a lift arm with a shorter 6-1/8" pivot. |
