Old 12-27-2010, 01:25 PM
JOHN SCHUTTE's Avatar
JOHN SCHUTTE JOHN SCHUTTE is offline
Question Transmission Storage Question
I recently got a transmission that came out of a 122. The PO had filled it with diesel fuel to help loosen up the shift forks. I drained the diesel fuel out so I could inspect the condition of the gears and luckly everything looked great. This transmission is going to be setting until next spring, so what should I do? Looking for a good but "cheap" way to refill it.
A: Fill with diesel
B: Fill with some cheap motor oil
C: Fill with UTHF or hy-trans
D: Fill with gear oil
E: Do nothing, leave it dry
Old 12-27-2010, 01:28 PM
Put in the amount of Hytran that belongs in it.
Old 12-27-2010, 02:04 PM
A: Fill with diesel
I would not leave it dry.
If you choose to fill with hytran I would physicaly roll it a couple of times like making a snowman,to help coat all internal surfaces to retard rust.
If you chose to use hytran like Matt says, you would need do nothing to put it in operation when ready to do so.
That would be the least cost option, with no wasted fluid of any kind.
Old 12-27-2010, 02:39 PM
Would it leak out the shifter when it is turned upside down?
Old 12-27-2010, 03:19 PM
Yes, it will. I wouldn't turn it completely upside down.
Old 12-27-2010, 03:35 PM
Thanks for the info guys! I will fill it back up and make a "giant snowball"
Old 12-28-2010, 10:22 AM
Default Update
Removed the rear end cover and drained the remaining diesel fuel out last night. While it drained made a new gasket out of some fel-pro 3046 gasket material. Tip- a .357 mag shell casing works great for punching out the bolt holes in the gasket. Cleaned up the mating surfaces and installed new gasket. I then removed the shifter cover and filled with one gallon of NAPA brand UTHF. I know, it's not HY-TRAN, but it is better than nothing. I will put HY-TRAN in next spring when I tear back into it. One question, what is the torque spec for the rear cover bolts?
Old 12-28-2010, 10:49 AM
I believe it's 30 ft-lbs, but check your service manual. There's a table of torque values on the first or second page.
Old 12-28-2010, 10:53 AM
Thanks Matt for the info. I looked last night in my manual but was looking in the wrong place.
