Old 10-30-2014, 03:28 PM
RedHawCadet RedHawCadet is offline
First of all that thing is awesome! Have you a model # for the pump? Also pulley dimensions or bracket drawings? Thankshttp://www.onlycubcadets.net/forum/images/smilies/beerchug.gif
Mark
1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights
1967 Model 102- mower
1965 model 70 - weights,rear lift and spring assist
Model 100 resto mod project, rear PTO, hydraulic lift
QA42 snow thrower
42in front blade
Grandpa's F-12 and Super M
Old 10-30-2014, 09:53 PM
IHinIN IHinIN is offline
Thanks!
I don't have a number for the pump. It came off of an early '70s Chevelle, but I'm pretty sure GM used the same Saginaw pumps for several years, the only difference being pulleys and the later ones had a slightly different reservoir.
I have no drawings, as I designed it on-the-fly. I believe the pulley sizes are 3",2",&6". Both belts are 3/8"x20".
Old 10-03-2022, 09:47 PM
xcookpac xcookpac is offline
I am new. But this is quite an impressive project. And the details are excellent. I am considering a similar project on my CC122. Thanks so much for documenting this build.
Old 10-03-2022, 10:39 PM
Tony h's Avatar
Tony h Tony h is offline
Originally Posted by Tony h View Post
This thread is old. So I'm way late to the game but EarlJ.. look into Volvo 240 series car PS pump. remote reservoir and I THINK reverse rotation as GM.
Awsome Creation Adam.. how is it holding up two years later?
As I'm reading thru this way old post, I was saying "hey, my '89 volvo 200 has a pump with external reservoir. Read further and I see your post funny.
Also thinking that you could mount PS pump the correct side if you made a tensioner such that the belt runs on the outside of the pulley not around it. I know, 8 years too late.
If I can't fix it , it must not be broken
Old 10-04-2022, 08:42 PM
Good luck with your project.
Old 10-06-2022, 09:18 AM
Quick question, regarding double acting hydraulic cylinder (from your post on page 2 of this thread): what is the length of hydraulic cylinder on your 100. In the the posting, I believe that you mention 1.5" bore with 7" stroke. But, not overall length. Your help would be greatly appreciated.
Old 10-08-2022, 09:41 AM
I believe the lift cylinder is 1-1/4” bore x 5” stroke. I’ll try to measure it this weekend. The cylinder on my front blade is 1-1/2” x 7”.
Old 10-08-2022, 11:00 AM
Ambush Ambush is offline
That was a cool, well executed project! I love "home made" that looks professional and yours certainly does. Great job!
Some of the vane type power steering pumps can be flipped to change rotation, but your mounting system is very functional and not sure you'd see any advantage.
Congrats and it must feel good when you're using it still.
Old 10-08-2022, 11:18 AM
Thanks for the quick response. I am mostly working on the power angle hydraulic cylinder sizing. I am trying to mimic your build with my own twists on it.
As a result, it would be extra helpful if you could provide the length of the power angle hydraulic cylinder (open or closed). This would be immensely helpful.
One other request, do you have a good pic of the mounting point and bracket attached to the plow base. IOW, in your thread I found a really good pic of the hydraulic cylinder attachment to the plow. But I was unable to find a really good pic of the power angle hydraulic cylinder attached to the plow frame base.
Many thanks in advance.
Old 10-09-2022, 07:41 PM
Snapped a few pics of the cylinder on my plow.
File Type: jpg 6BD82CB0-177E-4C13-9EFD-41E216DB9972.jpg (31.1 KB, 80 views)
File Type: jpg A5008CB7-616C-4F7D-B5EE-F9F61B3586E3.jpg (25.2 KB, 78 views)
File Type: jpg 33A47042-07B9-4021-8334-D554598EFADE.jpg (26.0 KB, 78 views)
