Old 01-31-2022, 10:58 AM
Rex B Rex B is offline
Originally Posted by Frank1541 View Post
See the link to a picture of the ported and non ported pumps. A ported pump can handle one or more external hydraulic circuit. It does not define how many circuits are used.
https://onlycubcadets.net/forum/showthread.php?t=4675
So the obvious difference is the two tubes coming into the front of the unit. Is that a good quick check?
My 1864 and 2084 appear to have the same unit, though neither has a 2nd hydraulic control on the dash.
Old 01-31-2022, 05:47 PM
Gary C Gary C is offline
I thought I saw a post or a u tube video of adding another valve adjacent to the one in the panel.
Old 01-31-2022, 08:50 PM
Frank1541 Frank1541 is offline
Rex B. Yes the tubes are how you tell if it is ported. They are the same no matter how many hydro circuits are on the tractor. You can add another valve to the older style cubs, 782 etc and the Cyclops cubs. I have second valve for the front outlets on my heavily modded 1541. Most Cubs had ported hydro pumps in the 80s and 90s.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 02-02-2022, 10:10 PM
Farmall450's Avatar
Yes,
2 way out to a control valve/bank of valves and/or PSV in the case of the supers (which then feeds aforementioned valve(s)).
