My manual says the double pulley should be greased twice yearly or every 50 hours, although I haven't spotted the fitting (I haven't looked since reading that). Replacing the pulley and bearing would be about $125, which I'd like to avoid but could stomach if i was absolutely sure it would fix the problem. Most of that cost is pulley, so maybe mine is salvageable. The fitting I greased was the idler arm assembly. Is that supposed to ooze grease out the top when its full? I have now looked and can find no grease fitting on the double pulley
Cub Cadet 2166 |
Mine doesn’t have a grease fitting on the double pulley either, only on the blade pulleys. Unless they mean just to remove the pulley and grease the shaft?
So my choice is to fix this one, fix my 108, or let the lawn overtake the house. I don't think I want to fix the 108 so that leaves 2 choices which I'm still mulling over.
Cub Cadet 2166 |
If you’re gonna replace the spindle bearings do both sides together. I tried only replacing one (since the other seemed fine) and still had bad vibration/noise. Replaced the other and now it’s fine.
Some of the double pulleys have grease fittings and some don't. I use a needle adapter to grease the sealed bearings in those that don't have a fitting. I've also found that the bearings are a very loose fit in the double pulley.
How would I know if the bearings are all that's bad? Would I just be looking for wear in the raceway or? I've been lucky and never had a bad bearing or spindle on my 108 in almost 20 years.
Cub Cadet 2166 |
Cub Cadet 2166 |
That’s what I mean. The bearings inside the spindles can be replaced without replacing the entire spindle.
But I’d shop around. Mine shipped with two 42” deck models - one you could gets entire spindles (with bearings already installed) for $30-40 each on eBay, but I just happened to have the one where spindles are $130 EACH so it was cheaper to just replace the bearings. |
If only I could find the double pulley for that price, or less.
Cub Cadet 2166 |
Looks like the 2166 only had one deck model so that’s good the spindles are cheap. As I said mine had two different decks and I just happened to get the one with expensive spindles
