Old 05-28-2021, 09:38 AM
cub123's Avatar
cub123 cub123 is offline
It sounds like your 782 has the IH cast iron rear end with the aluminum axle tubes. My 982 has the same setup and it has been fine even with a three point.
I would personally try to mount the radiator in the front, but if you can make it work in the back that would probably be fine, though you may have to add more venting. Whenever I do an engine swap the first thing I do is get the engine blocked up in the tractor and check the driveline alignment and clearance, as well as the front PTO alignment. Once everything is in place you can see if you have any other interference issues and proceed with measuring and fabricating engine mounts.
Old 03-10-2022, 09:01 PM
Luke Workman Luke Workman is offline
Cool The Diesel is Done!
Well, its been a good long while since I posted on this thread, so I figured I'd give an update. My 782 is running great with the Kubota diesel, and you can check it out on my youtube channel, as I have quite a few videos of it there.
https://www.youtube.com/channel/UCJS...Obi2FPQJCnSzaw
1982 IH 782 w/ custom diesel and cat 0 hitch
(Soon to be mine-) 1973 Cub 128
42 inch snow blade
46GT mower deck
Brinly sleeve hitch box blade
Old 03-27-2022, 09:48 AM
V30crewcab V30crewcab is offline
you should post some pics of your mounts and how you put it all together.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
