Old 04-11-2021, 09:54 AM
TheSaturnV's Avatar
Default 147 Stumbling Problem Solved: Weak Coil
I never posted a Q about this, but have been chasing my tail for longer than I care to admit on this one. After a complete rebuild of the K321 it fired up with ease and seemed to run really well.
Fast forward to the project sitting for a long time and picking it up again. I've been having to use choke every single time to start it, no matter how warm it is. Furthermore, any increase in throttle and it would stumble and die.
Around in circles I went, moving from timing, to valve clearance, to cleaning the carb. Rinse-repeat. My error was the assumption that since the coil was firing, there was no need to investigate that.
I found a replacement for under $11 and thought, what the heck. BINGO, that was it. It simply was not getting strong enough spark. I was then able to set the Hi/Lo on the carb and she throttles up nicely. Set the timing with my Sun gun and it's running like a champ.
What has me baffled is this replacement coil. No mention at all that it was made in chyna. It just came in a box with a Long Island, NY address. I feel like I've stepped into a time machine.
HTH
Old 04-11-2021, 01:37 PM
TheSaturnV's Avatar
Update:
The coil is from Intermotor of Poland.
Old 04-11-2021, 05:14 PM
Does it have the same resistance spec's as the Kohler coil ??
Old 04-11-2021, 05:32 PM
twoton twoton is offline
Interesting,.. most coils are at least 3 times that much. You have a distributor?
Old 04-11-2021, 06:29 PM
TheSaturnV's Avatar
3Ω resistance
My secret distributor is Amazon.
Works great, the true test will be to see how long it lasts...
Old 04-11-2021, 06:41 PM
Oh, thanks. Just curious 'cause I just ordered one of these today for one of mine that was leaking oil;
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I'll be curious to hear how yours stands the test of time...
Old 04-11-2021, 07:20 PM
3Ω resistance
Ignition Coils have a Primary and Secondary resistance. What is the Secondary ??
Old 04-11-2021, 09:38 PM
TheSaturnV's Avatar
Secondary is 8,440Ω
Old 04-11-2021, 09:39 PM
TheSaturnV's Avatar
I've got my bowl of popcorn ready too.
If you can, post your primary/secondary resistance numbers for that DB coil.
Old 04-12-2021, 07:02 AM
Here ya go....... Kohler Specs
