Old 03-05-2021, 10:26 PM
Ambush Ambush is offline
Originally Posted by sawdustdad View Post
Details on the engine problem...??
I had a bad noise that I thought was from the PTO and it wasn't. I'll never know for sure if it was the balance gears running on badly spalled shafts or the rough crank bearings. Crank bearings are new and the balance gears are not going back in.
Old 03-14-2021, 12:02 AM
Well with the pesky engine rebuild out of the way, I could get back to the loader build. Steel prices are high right now, but I was able to find a piece of 12 gauge at a local place that sells crop steel. It had a bulge right in the middle, so I negotiated a good price. As a cheap senior a good deal makes my day and a little press and hammer work took care of the dent.
Getting metal bent here is a costly deal so out came the plasma cutter. And an extra fifteen minutes of welding will save me $100.
I waffled quite a bit about the dimensions, but the plate size helped make my decision. I didn't want the bucket overly deep, but still some volume for possible snow clearing. Ended up 22" deep, 18 1/2" high and 42" wide. The box is tacked up and ready to weld. I have a lot of 3/8" X 2" flat bar, so that means that's what the cutting edge is going to be and I'll have to dig around for any bolsters.
Old 03-17-2021, 09:46 PM
Made some bucket progress over the last few days. My son-in-law works at Finning Tractor and he keeps an eye on the scrap steel bin for me, so I end up with quite a bit of yellow steel that gets repurposed. I like free!!
The bucket is pretty much done except for a bit of welding.
Old 03-17-2021, 09:52 PM
After the final fit on the quick connect was satisfactory it needed some wire brushing and grinder work. I'll probably use it a bit before painting.
Old 03-17-2021, 10:02 PM
And the first scoop of snow!! I have no weights on the wheels or rear yet, so with a full bucket the one rear tire came of the ground when I got off the seat. I had to dump some so I could take a pic. I put the set of wheel weights I have back on after, but I'm going to need a bunch of weight behind. I better get busy building a sleeve hitch and a weight system. I can see that power steering would be a real asset too.
The loader definitely has lots of speed even at a high idle and plenty of lift.
Old 03-17-2021, 10:09 PM
Cubcadet_107's Avatar
Very nice!
But... when it's all fully complete and painted up nice, we need some glam shots!!
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 03-17-2021, 10:31 PM
guido guido is offline
Way cool Ambush. Like CC107 stated... We need glam shots and a video.
Alan
Basket Cases: 129, 1450 sold, 1650
125: 48" Mower Deck, Windbreaker Cab
127: 3 turn steering gear, Spring Assist, Sleeve Hitch, 48" Mower Deck, Dozer Blade
147: 3 turn steering gear, Spring Assist, QA36a w/Xtreme Motorworks Wings
Old 03-17-2021, 11:12 PM
Getter-Done's Avatar
Getter-Done Getter-Done is offline
You have done a Great Job on this.
I like It
You are Truely a Craftsman.
Old 03-18-2021, 07:11 AM
Looks real good.
Old 03-18-2021, 07:43 AM
IHCubCadet147's Avatar
Nice work!
