Old 01-31-2021, 12:15 PM
ironman's Avatar
ironman ironman is offline
Why are you worried about chassis numbers??
Old 01-31-2021, 02:06 PM
Who is on first?
The front seal is really the back seal,-- meaning toward the rear of the tractor
Be careful.
The " rear" seal is the PTO/crankcase cover seal.-- toward the front of the tractor.
Just to keep everyone on the same page.
Some parts reference's continually mix them up.
If one is replacing both seals there is no problem.
Old 01-31-2021, 03:04 PM
ironman's Avatar
Who is on first?
Be careful.
Then again, to thicken the plot, if it were a Case tractor the front seal would be on the front,
but if it were a Wheel Horse the front seal would be on the side.
Old 01-31-2021, 03:36 PM
I went by what.....Kohler.....calls it. After all, they should know.
Old 01-31-2021, 05:32 PM
And if it was a KT 17 vertical engine, the flywheel seal would be the top seal.
Thus the designation flywheel end or PTO end.
Old 01-31-2021, 05:45 PM
ironman's Avatar
Don't matter how you designate it because one things for sure, that is....
The one that needs replaced is always the one that takes the most work to get to.
Old 02-01-2021, 05:13 PM
fxrglide91 fxrglide91 is offline
Well I ordered seal 52 032 10 S. We'll see if it fits. Thanks for all the help.
Old 02-03-2021, 10:30 PM
CubDieselFan's Avatar
Post a picture of the tag on your tractor frame.
Old 02-10-2021, 07:48 PM
Who is on first?
Be careful.
Yep you are correct. I ordered the front seal, by diagram, (52 032 10 s) which is actually the rear seal. So now I ordered the rear seal , by diagram, (X-583-5) to put on the front of the motor PTO side. Who would have guessed. Thanks
Old 02-10-2021, 09:00 PM
Who would of guessed? ME!
The front of that engine is the flywheel end, the rear is the pto end. No matter if it is on top,in a vertical application, sideways or longitudinal mounted,--- or cub decided to drive off the flywheel end.
No harm done, if it was time to replace one, it is time to replace the other, and you already have one now.
Now if you happened to removed the crankcase cover while changing the PTO seal and it had a paper gasket between it and the block, replace it with a paper gasket. If it had RTV as sealant use RTV to reseal it. Make sure you put the seal in deep enough so the centering tabs on the PTO clutch have a place to fit into. but not too deep. Use RTV sparingly if you use it. More is worse not better,---- ALWAYS!!
As it gets into oil passages and clogs them causing catatastropic engine failure.
FWIW: Kohler wrote the service manual/parts lists for their engine, no matter who purchased it and installed it in various ways.
