Old 09-09-2020, 10:05 PM
SS5150's Avatar
SS5150 SS5150 is offline
Yeah I considered the harness from my donor (a 2185 or 86, I don't recall now) but it just didn't seem like the fitment to my tractor chassis was that nice. That said, my modified harness isn't all that great either, but it's worked and been reliable.
That is a nice looking 1711. Don't see those too often.
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 09-10-2020, 07:38 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
Originally Posted by Farmall450 View Post
Yes, I was planning on keeping several of the warning lights (e.g. low oil presure) and either hiding them below the dash or even under the hood. Don't really need the disengage pto or press brake or whatever else they have (IIRC there are 4 lights) but oil pressure might be nice.
I'd assume the "oil sentry" would kill if it loses pressure anyhow?
In the event of low oil pressure, the engine does not shut down on these. The light on a 1811 and newer is a nice addition, but I went a step further on my tractors. I added a mechanical oil pressure gauge made by Stewart Warner. That way you know exactly where the pressure is and if there is an issue that otherwise would be unknown with a lamp that illuminates at 5 psi or less.
Old 09-11-2020, 07:55 PM
Farmall450's Avatar
Looks nice. The oil Sentry on the donor engine doesn't kill ignition? It seemed to indicate so. I'd be using a new (period correct) lamp on the existing trouble light.
Old 09-11-2020, 07:57 PM
Farmall450's Avatar
Thanks. No, just a renumbered 782 but decent. Just wish it had front remotes (1712)!
Mainly want to try out that snowblower.
Old 09-15-2020, 10:32 PM
Farmall450's Avatar
Got the engine and harness out yesterday. Looks like the 1711 engine driveshaft coupler will bolt right on, and with some luck I can get it close enough to attach.
That leaves the wiring being my last hurdle for now...I'm planning on keeping the keyswitch, but would really like to use the original style PTO switch vs the clunky yellow variety. This would be fine, with everything but the brake sensor. I'm wonder if I simply swap the N/C and N/O wires I'd get lucky without ill effects, but I haven't thought through it quite enough to be sure of that yet.
Old 09-15-2020, 10:34 PM
Farmall450's Avatar
Wiring schematic
https://www.cubcadetpartsnmore.com/c...ing-schematics
https://www.cubcadetpartsnmore.com/u...iring/2176.pdf
Old 09-21-2020, 10:23 PM
Farmall450's Avatar
Well, made some progress this morning. Unfortunately, I've reached the conclusion from dry fitting the engine that the driveshaft will have to be extended about an inch and a quarter. Even if I could move the tank/bulkhead back, it would still probably be too tight and the airfilter cover would be unremovable.
I bolted up the rag joint coupler on the engine after fabbing up about an inch worth of bushings to push it out to the thickness of the engine's original coupler, leaving room for the driveshaft to stub through the pilot bearing.
I also got the driveshaft and tunnel cover out, and plan to decide the engine's final resting place (with new muffler on) and then make the shaft fit. Also, after it randomly started leaking on me, I've decided the quarter turn oil drain is going goodbye.
Old 09-23-2020, 10:59 PM
Farmall450's Avatar
Ordered some $2 motor mounts from NAPA that should take a bit of vibration out. Might cut them in half to stop the engine from raising too much. Just got the muffler on, and will test fit the grill/hood with the engine's front mounts in the rearmost OEM bolt holes. Will have to mark and drill 2 more holes + oil drain egress.
Muffler is going to take some considerable re routing to get out the front left, let alone right like OEM.
Stay tuned.
Old 10-05-2020, 11:21 AM
Farmall450's Avatar
Some progress I forgot to post from last week. Engine in, oil drain complete, bolted down with motor mounts and drive shaft bolted up.
Gotta love holding the carriage bolts on for the rag joint while trying out fitment for a new driveshaft length (I measured for a finished length, which seemed right on the money, but am going to spin it over a few times with the starter to be sure it is where it wants to be before I weld it solid).
Hopefully tonight I can get most of the electrical sorted out and have a running unit.
Old 10-05-2020, 05:07 PM
Frank1541 Frank1541 is offline
I am not sure it this is an issue or not. Did you check to make sure that the PTO pulley is in the right place, front to back. The mounting holes on the plate are in a different place for the Command engines.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
