Old 06-09-2020, 10:55 PM
IHCubCadet147's Avatar
I put tubes in two tires on my 125. The one rear was dry rotted and leaking, the one front had a hole that was previously plugged and leaking. I tried a patch in the front one first, but the PO had Slime in it and the patch wouldn’t stick so I had to get a tube. Now I won’t have to stop every hour to put air in my tires.
Old 06-16-2020, 09:58 AM
Got the basket case 126 I have been resurrecting/working on these past several months off the table for a run around the yard.
Added a 3 point and spring assist, driveshaft and coupler from Jeff and got the lights working with a new switch and wiring.
The seat has got to go though!!
Old 06-16-2020, 11:25 AM
jbrewer's Avatar
jbrewer jbrewer is offline
That's looking really good Fins!
"Saved" basket cases are the best, and I agree... time to take the sawzall to to the seat :-)
Nice work!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 06-23-2020, 10:15 PM
Nice 126, you have there!
Old 06-24-2020, 12:30 AM
cub123's Avatar
cub123 cub123 is offline
The PTO bearing went out on the 123 when I was mowing this week. Finally got it pulled off, but is was a pain because the PO broke the top of the set screw For the locking collar.
File Type: jpg 6C1A8C13-E782-4781-8625-F579E486E80A.jpg (31.2 KB, 200 views)
Old 06-28-2020, 04:18 PM
cub123's Avatar
I got the PTO back together on the 123. I found a 2 pack of PTO bearings on amazon for $18. Most of the bearings by this company have good reviews, I guess I’ll see how it holds up.
https://www.amazon.com/Cub-Cadet-455.../dp/B072KQ8QSB
Old 06-29-2020, 11:41 AM
mrjeep81's Avatar
mrjeep81 mrjeep81 is offline
Default Routine maintenance
I just finished installing a new wire harness, some routine maintenance, and a freshened up paint job on my sisters 1250. I thought it’d be fun to park my
“1450 SGT” next to it for a comparison.
https://www.youtube.com/watch?v=pC1C...&feature=share
1450SGT
1641
528 SWE Snowblower,
Old 07-12-2020, 05:03 PM
144017018 144017018 is offline
Finished giving the 107 a once-over, fluid change, etc and got it back together. Ran it through its paces in the yard and finished right as a storm rolled in. Everything worked well, including catching a rainbow at the end! My assistant, Noelle, has taken a liking to the 107; she barks at the 1440 when I'm running it, but just observes the 107. Guess she likes the old Kohler-powered IH iron...
Old 07-12-2020, 10:21 PM
Looks good!
Old 07-13-2020, 08:25 PM
twoton twoton is offline
I made a new drag link to connect the governor arm to the throttle arm for my 1450.
