Old 06-23-2020, 12:44 PM
TomRom's Avatar
TomRom TomRom is offline
Default Peco Vacuum Attachment
Just got this the past weekend from a forum member charlie105 (Thanks again Steve). Brought it home and pressure washed it then did a test fit on my IHCC 1250. I think it's really kewl. PO found the rest of the bag and is sending it to me. It needs some work but mostly complete, engine still turns over. Thought you might enjoy some pic's.
IHCC - 122, 125 x2, 127, 108 x2, 129, 149 x2, 1200, 1250, 1650 x2. SEARS - Six Speed Suburban 10HP, Quick Speed Change Suburban 10HP, Six Speed GT18 Twin. ECONOMY - Country Squire. CASE - 580B CK tlb. That's it for the 4 wheel ones....
Old 06-24-2020, 09:56 AM
charlie105's Avatar
charlie105 charlie105 is offline
You are welcome !
Old 06-25-2020, 12:08 AM
That is more than just a leaf vac system. The original brochure also advertised it as a cub cadet carry all for the back of a cub. It showed several cut logs stacked in that basin. They do a tremendous job collecting the leaves from the yard, too. Also, take care of the scoop that fits on the deck. They were made of aluminum and often cracked and that part alone often sells for $100+ on EBAY. I also think you are missing a swing arm that locks into the two sleeved holes in the frame to help support the unit.
Nice looking set up. You will enjoy it!
Tags
ihcc
