Old 05-15-2020, 08:02 AM
cooperino's Avatar
You can see the piston through the spark plug hole???!!!
I kinda doubt that.
Valve maybe, the piston is on the other side of the engine
Great point fin, Mind was in another place when reading the post.
Old 05-15-2020, 08:31 AM
Rwgarrison23's Avatar
Rwgarrison23 Rwgarrison23 is offline
I kinda doubt that.
Ummm, you might be right. I wasnt thinking clearly because I wasnt thrilled about what happened because I spent so much money on it going through everything and this happens all sudden. Just dont understand.
Old 05-15-2020, 09:09 AM
When I 1st got this 124, it was badly neglected and over few months after owning it, I went through everything, all the way down to the wire harness to the 2nd trans put in and it ran beauriful up to last tuesday started run rough. Thought having me leaving key on by accident all night had something do with it.
Old 05-15-2020, 10:51 AM
he could have seen the piston, among the heads that were used on these K301s over the years they moved the spark plug hole. who knows if the head he has now is original or has been replaced?
Old 05-15-2020, 11:02 AM
I was thinking the same, thank you. I'm not sure what original and what not.
Old 05-15-2020, 11:45 AM
cooperino's Avatar
Ive seen some very slight variation of position of spark plug hole on different heads for K301's but all were still over valve side of the head..
Anyone got any pics of one over piston? Not doubting it.. Just never seen it.
RW? got a pic of yours?
Old 05-15-2020, 12:04 PM
Not much room between the top pf the piston and the head when at TDC!
It's a very tight squeeze there.
Think about it.
What kind of gas are you burning?
Corn gas??
Any additive such as MMO?
I use MMO in all my older equipment, 1 oz/gal
Old 05-15-2020, 12:23 PM
ironman's Avatar
ironman ironman is offline
Pics of K301 heads....
And for the record, I have had the plug blow out of the head.
I was mowing on a 122, plug blew out, sounded like a gunshot, engine died, and I thought the neighbor had taken a shot at me and hit the motor.
Old 05-15-2020, 12:26 PM
What did you do to fix it? Get new head?
Old 05-15-2020, 12:28 PM
ironman's Avatar
Answer, yes.
