Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Onan Engines
Old 04-01-2020, 09:00 AM
cooperino's Avatar
Originally Posted by EarlJ View Post
I've done compression check wet cylinder has 90psi and the other has 85psi. I'm thinking to order one of the nikki carbs from ebay. Pretty sure my carb is just wore out.
Ok. Well, both of those numbers are right at the minimum for the dry test. Did you check dry?
Either way thise numbers seem really low for a fresh build. Also there should be no mre than 10 psi difference between cylinders. A fresh build usually comes within 1 to 2 psi across cylinders.
Also, did you do a leak down test?
Old 04-01-2020, 09:43 AM
I'm thinking those are low numbers too. I'd also do a leak down test to see if you have any other issues. Maybe even try and switch the plug wires and coil connections too. What carb is on your engine?
