Old 06-05-2009, 03:32 PM
Merk Merk is offline
by murphycc
Merk do you have a part number for the needle bearing?
Part number for bearing. (McMaster-Carr part numbers:
http://www.mcmaster.com/#)
bearing: 5909K32 Price-$2.66
Washer: 5909K45 Price-$.95 each-need 2
Locknut: 92501A030 Price-$9.90 for 100 pcs
Any good hardware store like ACE should have them.
Sorry for not responding sooner.
Old 06-05-2009, 03:39 PM
by dross
Murphy, Let us know how long that open bearing lasts. Please don't think this is a "dig" I am curious.
Dross-Good point. I don't consider your statement a dig.
The only way to know is give a try. It will be an easy change if it doesn't hold up. Not know how everyone's work looks...I'm only working 32 hours a week. I've been looking for ways to make and save a few $$$.
Old 09-15-2009, 08:19 AM
nathans nathans is offline
Oldrustycars, do you have a part numbers for your setup?
Old 09-15-2009, 08:55 PM
oldrustycars oldrustycars is offline
http://cubfaq.com/steeringrebuild.html
the bearing is available at any bearing supply, like Motion Industries. The thrust washers at any good hardware store. Don't use flat washers, get proper thrust washers, they are ground perfectly flat. Any parts in the box are available at any Cub Cadet dealer.
Old 05-19-2016, 08:27 AM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Curious to see how well your upgrade worked with the needle bearing.
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 05-19-2016, 10:51 PM
Bob95065 Bob95065 is offline
I use this style thrust bearing.
http://www.mcmaster.com/#thrust-bearings/=24b0wk
Here is the the thrust bearing set up on my 70 steering:
I did the same thing n my 1450 a couple of years ago and on my 1000 a couple of months ago. They are holding up fine so far...
Old 05-20-2016, 05:41 AM
It has been 7 years since I restored my 70. I haven't had any problems with that set up. Just finish spraying the yard.
Project Uncle Dick
Cub Cadet 70
Old 05-20-2016, 08:34 AM
vr4Legacy's Avatar
Great. with the light load on the steering box, I couldn't see it being an issue.
I might do this next. Thanks for the pics and links to part numbers.
-Jason
Old 05-20-2016, 08:51 AM
Dale:
I have a question. What about dust/dirt getting into that roller bearings...??
Old 05-20-2016, 10:04 AM
vr4Legacy's Avatar
Dale:
With the washers and the nut down tight, how much could really get through?
-Jason
