Old 09-16-2019, 08:21 PM
they are both right hand NF threads
Actually there are 4 joints.
2 on the drag link and 2 on the tie rod.
all right hand threads
RIGHT HAND 3/8-24 NF thread
Old 09-18-2019, 12:13 PM
DownNdirt's Avatar
DownNdirt DownNdirt is offline
Huh, that's odd. Figured they would be left and right hand like my Deere is. Thanks for setting me straight. Glad I waited to order them. I will order 4 right hand thread heim joints then.
'78 1250, '79 1450, '77 1000
Trapped and released: 124, 1000, 72, 1211
(JD) '70 140 H3 patio yellow, '74 140 H3, '87 332 diesel
Attachments: too much to list
Old 09-28-2019, 05:48 PM
DownNdirt's Avatar
So got my HD greasable tie rod ends and steel for the cradle mod from MCmaster the other day. Just need to order some seals next week and hopefully this project will be underway.
Old 10-11-2019, 02:00 PM
DownNdirt's Avatar
So this week I hope to start the disassembly of the ol' girl and get some progress done.
Old 11-30-2019, 08:28 PM
DownNdirt's Avatar
So some unfortunate news tonight... Got the engine unbolted and head off, and found some serious damage. Thought it was gonna be an STD piston but it was bored .010 over. For how bad it look it ran pretty great. Not sure what the plan is now, but at least I can fix the other things that are messed up. The grooves are fairly deep and more than likely will have to be rebored.
Old 12-01-2019, 07:40 AM
Yup, it looks like a re-bore is in store.
Old 12-01-2019, 09:54 AM
Have your machine shop, or whoever is doing that work for you check it closely once it has been tanked.
Be sure and take them the crank as well, it is likely to have been turned .010 already as well.
The original 321 block I planned on using in my 1450 turned out to be a boat anchor as it was found to be cracked once it was properly cleaned up.
Good luck!
Old 12-02-2019, 05:36 PM
sawdustdad's Avatar
Even if the crank was previously turned .010 under, you can order a .020 under rod if you need it. I've had to do that a couple times. batkt4kids is the ebay seller. He can get you the .020 under rod with the rebuild kits he sells.
put some paint on the flywheel timing marks.
In the process of putting a K301 from one of my 129s back together right now.
Old 12-04-2019, 12:54 AM
DownNdirt's Avatar
Hopefully I can get to seeing if the carnage goes any deeper today and weigh my options. If worst comes to worst I have a 1650 with what seems to be a k301 so it may become the replacement (provided it isn't as bad as this one). The ol' girl will probably have to go lower on the priority list until spring more than likely. I've got my 1450 to revive first.
Old 12-11-2019, 01:33 PM
DownNdirt's Avatar
So last weekend I got a bit of free time and tire down the block some. Got flywheel, all external accessories, front bearing plate and piston out. Undirtu lately the last PTO stud stripped off and will not come out. And having a heck of a time trying to figure out how to get the valve keepers off. But it's pretty much disassembled and should be apart by Saturday. My spring conoressor is kinda junky and I'm having a hard time keeping the tool from flying off (because it isnt straight).
