Old 08-22-2019, 09:16 PM
MARK (LI)'s Avatar
MARK (LI) MARK (LI) is offline
Default Sloppy steering on 129 overcome
A combination of replacing the cam follower, tie rod ends, installing a thrust bearing, and a lot of grease in the steering box, is not power steering by any means, but a lot less play, and more immediate response.
Old 08-23-2019, 06:01 AM
YUP, usually makes steering a lot easier. Good to hear about your outcome.
Old 08-23-2019, 04:10 PM
If you didn't pull the spindles, pull them, clean and regrease and that helps a lot. The old grease turns hard and doesn't lube as well.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 08-24-2019, 04:14 PM
MARK (LI)'s Avatar
Randy
I had tried that before all the other work....would really like to replace the front axle with one with 1" spindles
Old 08-24-2019, 08:19 PM
Did you get the bushings to rotate inside the cast iron axle?
One time I had one that had worn the end of the bushings so bad, I had to grind some off the axle to get the bushings to rotate again,,,
I have never purchased a GT that did not need the bushings to be driven out and cleaned,,
Old 08-24-2019, 09:06 PM
MARK (LI)'s Avatar
Yeah...I was lucky they were both snug fitting...no wobble and not jammed in....replacements are available from a few guys that specialize in Cub steering parts
