Old 06-01-2019, 03:56 PM
Higgins Higgins is offline
Default What to do?
Good day and I'm looking forward to gaining knowledge from the best cub owners anywhere.
I picked up a hodgepodge of an old cub. The frame is that of a 127, the hood says 107 and it has a B&S 10-hp motor. I would like to bring it back to original (or close), add a front loader and use it clean out the stalls in my hog barn. I was at bone yard and found a K-241 (sn:C-195835 Spec: 46329D). I know the 127 came with the K-301 12-hp, however if my information is correct, the engine blocks are the same...? I acquired the service and parts manuals for both 127 & 107 as well as the parts list for the Kohler 10-hp that listed all the specs.
I got the Briggs to run and tested out the drive on the tractor, everything work good. Changed the hydro fluid and filter first off.. it was setting outside for who knows how long.
When I tore down the Kohler engine , it was obvious someone was in it before. The connecting rod bolts were loose and the connecting rod itself was not the same part number as listed for the spec on the blower cover ID tag. It was a 4705905 with a hole drilled in it and the crank bore was shot... the spec calls for a 4706702 connecting rod. The crank journal need turned and the cylinder bore needs taken out .010"-.020" not sure what I want to do. I'm getting windy here, so Ill get to the point.
Is there any way to identify the block other than the tag on the blower? With what I see, the blower cover could even be incorrect. I work in an iron foundry and know all about casting numbers and cast date codes, but cannot locate any ID on the block or oil pan.
Should I just go for the 241 rebuild or try and do a 301 12-hp out of what I have?
Some day I'd like my grand kids to have it as a remembrance of papap..
Old 06-01-2019, 08:01 PM
twoton twoton is offline
Welcome to OCC Higgins.
Old 06-02-2019, 08:47 AM
cooperino's Avatar
Welcome..
Your time your money. I see good used k301's on craigslist all the time. I picked up a good one for 50$ a couple weeks ago with PTO and SG on it.
Best of luck with it
Old 06-02-2019, 09:07 AM
Welcome to OCC....
Looks like you have a challenging project(s).
Old 06-03-2019, 11:46 AM
Thanks. I have tried CL without success, unless I want to pay big bucks for shipping. Not.. It's a winter project so no rush. Got $100.00 in the 241. The way it will work is as soon as I get the 241 rebuilt, CL will have a dozen 301's within a couple hour ride.. never fails.
Old 06-03-2019, 05:04 PM
RLause's Avatar
RLause RLause is offline
Welcome, where in Michigan are you located?
Richard
Old 06-13-2019, 05:55 PM
I have 2 K301s and a M14 magnum but they are all "wide base" Kohlers.
I have the same issue I cant find a rebuildable narrow base one to save my life. I too have a 10hp that I "settled" on.
Old 06-21-2019, 12:30 PM
Default What to do
Well, the cylinder bore needed .030" over to make right, no sweat, got the piston and rings. The crank needed down sizing by .020, got the rod to fit, no sweat.
Now trying to locate a starter/generator. The original Kohler pn was C-231262 per spec 46239 parts manual.. Didn't realize there were so many variations.
Also will require the drive pulley # 231591 and starter pulley# 231278. This project is like a treasure hunt with corn mazes and dead ends, still digging though. Keeping the final results in sight.
Any input will be appreciated. maybe not followed but still appreciated..
Old 06-21-2019, 12:43 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
For what you can buy a decent 127 for I'd find a good one and keep this one for extra parts. On the other hand, if you enjoy tinkering it's an enjoyable way to spend all your discretionary income.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 06-23-2019, 05:12 PM
Welcome to OCC!
Tags
k241, k301
