#641
https://www.onlycubcadets.net/forum/...ad.php?t=52389
#642
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
#643
I put a rear lift on my 149 this morning, and I hope to put one on the 106 tonight!!
Grumpy old 149/1A tiller, Trusty Rusty 106, & a Massey Ferguson 10 to work the garden, Tiny Snapper to mow the lawn. Slowly accumulating attachments and quickly driving the neighbors crazy on a half acre homestead.
#644
I put the mower deck on my 126 tonight.
#645
Dad's LT1018 always looked showroom condition. The engine blew a rod after 780 hrs. I was lucky enough to find a scruffy looking LT1024 with low hours on it. The 50 inch deck was beyond repair but the engine started and ran good. That 24 HP V-twin Briggs fit right on his LT1018 in place of the single cylinder.
(1.) Wiring harness had to come with the engine. (2.) Engine shroud under the hood needed to be swapped. (3) Choke and throttle cables needed to come along with the engine. Everything fit right on....Perfectly..... I think she's a little overpowered for a 42"deck (if there is such a thing.) Dad noticed it uses a little more gas than it used to. That's cause he is a meticulous and detail oriented man of 87 yrs. He loves his lawn and I love it when he feels good enough to get out there on his mower.
#646
I put led headlights on my 680 and 682, DANG THEY ARE BRIGHT!!!!!!!!!
#647
Cleared out some bushes and garden beds
#648
Got my rebuilt hydro valves back, changed filter and hydro fluid.
Now my question on my model 682(142682399) serial #2050584U710035. Is there a spring on the brake pedal, and mine does not look like any diagram that I have found.
Walter |
#649
Grass Boarding!
IMG_20190420_180510.jpg |
#650
The grass boarding looks like a blast! Why did I not think of that when my daughter was growing up?
As to my cub activities for the day....let's see...got the transaxle bolt holes lined up and joined back to the frame (this took some doing) after having the tractor separated for the past few months in order to do a cork gasket job. Also hooked up all the linkages, took off the rear left tire in order to get the lift lever assembly pin put back in, then hooked up the lift bar. Now ready to pick up my rebuilt engine from a local dealer. Also will be giving a second coat of paint to the fender assy. Already sanded and painted the frame, tins, and most of the transaxle. This is in no way intended to be on the level of restoration like many of you do, but simply trying to spruce up the old 129 a bit - especially if I decide to sell it.
