Old 11-16-2010, 01:14 PM
Larry64's Avatar
Larry64 Larry64 is offline
Default ISO mounts
OK, whats the best way to fix the ISO mounts on my 1650, The rubber is shot. Are there better after market bushings? I know about welding in the cross piece.
1975 Cub 1650, JD LT155
Old 11-16-2010, 01:20 PM
NiasNeb's Avatar
NiasNeb NiasNeb is offline
Default Mounts
My research has shown that the best thing is to take the plunge and buy the factory mounts. The other mounts, from what I have read, offer more vibration. I also made the cross member change too and between the two it runs pur-fectly. While it is expensive (more than I think it should be) it is worth it to me.
Nias Nebraska
Old 11-16-2010, 01:29 PM
Buy the mounts from your local Cub Cadet dealer. You won't regret it.
Old 11-16-2010, 02:06 PM
I just did my 1250. I tried the after market first... Mistake... Got the cub rubber and am much much happier with the outcome. Don't forget to do the cross brace mod while you have the motor out.
Brace Mod:
Old 11-16-2010, 06:18 PM
pattonacres pattonacres is offline
we sell and have installed lots of the aftermarkets.I have had good luck with them however keep in mind your can get them for under $20.00 and the ones from cub are over $80.,you get what you pay for.I would say the new cub ones are almost bullet proof.If we are selling a $5-$600. tractor we can`t recover the $80. so we use aftermarket,I think this also holds true to a guy that wants to have several cub cadets ,hard to pull the trigger on that amount of money for something that may only get used a few times a year.
Old 11-16-2010, 07:03 PM
Larry64's Avatar
Thanks for the help. I'm going to go for the factory mounts and welding in the cross brace. I use this tractor summer and winter. I don't want to pull that monster single out again.
Old 11-16-2010, 09:52 PM
Lmercer Lmercer is offline
I bought a used set of the Cub mounts in very good condition for $25 on eBay.
Old 11-17-2010, 10:15 AM
thehud thehud is offline
I'm running the "aftermarket" suspension pieces on my 1250 and honestly they do fine. The K series engines do vibrate a considerable amount at certain RPMs, so either of the options isn't going to take all of that away.
Old 11-17-2010, 12:10 PM
Sugarmaker's Avatar
Do you folks have the specs for the mounts in question?
Like size shape and rubber durometer? Just courious to see what you get for $80?
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 11-17-2010, 12:53 PM
This is for one corner. The kit runs about $20 per corner.
