Old 03-21-2019, 02:35 PM
twoton twoton is offline
Default Temporary fuel tank...
I need to make a temporary fuel tank for a tractor I am working on and was thinking about using 4" PVC pipe. Anyone know if it is compatible with diesel??
Old 03-21-2019, 03:04 PM
Fuel will not dissolve it, if that is your question.
But there might be an issue with static electricity in some large applications without grounding.
In your situation using it for a temporary small engine fuel tank, I don't see an issue.
Old 03-21-2019, 04:05 PM
Static electricity you say...Hmmm...
Now you got me worried there ol'George.
Old 03-21-2019, 04:42 PM
We have a temp tank at work made out of PVC. We use it for gas and diesel and have been using it for 10yrs now without issue.
Old 03-21-2019, 04:50 PM
You use it to run tractors that you're restoring?
Old 03-21-2019, 05:22 PM
john hall's Avatar
Got one off a Briggs, must be 30 years old--it was on a cement mixer and still has cement splatters. Has a valve under the bottom and a bracket where we can tie it on or bolt it down (if possible).
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 03-21-2019, 05:26 PM
Valve's a good idea.
Old 03-21-2019, 05:51 PM
We use it to test run tractors so we don't have to mount the real tank.
Old 03-21-2019, 06:05 PM
I'm checking out a tractor for a friend. It's been sitting in his barn (that I built for him) for over 20 years. The tank, even though full of red fuel, is very rusty. The filter had some brown crud in it that felt gritty but my magnet wouldn't pick it up. Maybe algae but I never came across any gritty algae???
The fuel that came out of the filter was surprisingly clean but did not smell like any diesel that I ever smelled so I drained the whole system and plan on setting up the temporary tank with new fuel line and filter before I try to crank it over.
Old 03-28-2019, 08:12 PM
The Surplus Center ,has some cheap metal tanks
last time I looked
