Old 05-30-2009, 12:54 AM
B1jetmech's Avatar
B1jetmech B1jetmech is offline
Default Engine Cradle Upgrade
I understand the engine cradle upgrade for wide frames allows for longer idolater life but does it help cut back on engine lope? Seems like it would.
At lower engine speeds mine just shakes like a Muscle car with a radical cam in it! Want to calm it down so it doesn't shake other parts loose and cause cracks in certain places.
Chase
Old 05-30-2009, 02:11 PM
greg r greg r is offline
What is the RPMs at idle?
What do y'all use for a tach?
Old 05-30-2009, 02:41 PM
RPalmer's Avatar
RPalmer RPalmer is offline
I use a Sirometer. Sold as a Tecumseh part # 670156 RC.
I guess I would like a digital tachometer but this works and is kinda cool once you discover that it works on the principle of organized chaos.
Old 05-30-2009, 04:25 PM
Not much different from a reed tach.
I'll check the local power equipment shop.
One question though, what about using it on engines that have those counterbalance shafts? I think the 16Hp Kohler in mine is supposed to have one.
Thanks
Old 05-30-2009, 04:57 PM
Merk Merk is offline
My Dad added an extra brace to the cradle on his 1450.
This tractor is used only to work ground (plow-till-cultivate).
Old 05-30-2009, 05:18 PM
RPalmer's Avatar
Thanks
I have used it on both types. With and without balance gears. It works.
Old 05-30-2009, 07:02 PM
Thanks very much. I'll get one ordered Monday.
Old 06-01-2009, 08:44 AM
drysumpjet's Avatar
drysumpjet drysumpjet is offline
Anybody ever use this tach? Price is right.
http://enmco.thomasnet.com/item/enm-...1001&forward=1
Presently, I set the governor top speed with a Stihl chainsaw tach, (almost a must have for tuning chainsaws), it works by holding it next to the spark plug, thru it's internal inductive pickup.
Also, I understand it's not good to idle a K Series single too slow as that can damage the compression release system.
Old 06-01-2009, 08:51 AM
The ACR system is suppose to engage/disengage at around 600 RPM's. This is well below the minimum RPM for idle.
Old 06-01-2009, 09:03 AM
drysumpjet's Avatar
Agreed, on the 600 RPM idle spec, I should have mentioned that in my earlier reply, Thanks.
But many are tempted to slow the engines way below that spec, just for the "cool" factor. The heavy flywheel on a K series single will allow for that.
