Closed Thread
Old 09-06-2017, 11:19 AM
three4rd three4rd is offline
Default What is ok to use on my K-301 aluminum head and gasket to clean off the carbon?
Just wanted to get more opinions on this. I've read and heard where some people use a dull putty knife, wire and brass brushes, etc. The manual calls for only wood or plastic scrapers. My plastic putty knife really doesn't do much - gets dull right away.
I have a small wire and brass brush, if that would be ok to use. Or would some sort of solvent - carb cleaner, etc. - do the job?
Old 09-06-2017, 11:27 AM
I would use brake cleaner and a wire brush if you don't have access to a bead blaster.
Old 09-06-2017, 11:37 AM
OK...so wire will not scratch the aluminum?
Old 09-06-2017, 11:45 AM
If you get crazy it might but even if it does it won't affect anything.
Old 09-06-2017, 02:02 PM
Agree. But if you plane it like you're supposed to after cleaning, it will correct any mistakes.
Old 09-06-2017, 04:40 PM
All cleaned. Have to get the 320 grit paper to do any planing. I ran a straight edge across the head and checked for light coming under the sides. It's really pretty good. There are a few areas where I see light showing under the straight edge, and the straight edge has just the slightest bit of rocking back and forth right near the one edge (when placing it across the widest point) so I suppose this indicates some warpage.
How do you know how much planing to do? In Tim's video, he's removing deposits from the head, and then stops around 20 minutes after they are all off. I already have the head clean though, so what means of checking is suggested to see if it is indeed planed down sufficiently? Just use a straight edge again and check for low spots?
Old 09-06-2017, 05:23 PM
That's flat black paint you see in the video and that was done to make it easier to see on camera, in person it will be very obvious where it's been sanded and where I hasn't so go until it all been sanded.
Old 09-06-2017, 09:21 PM
That (sanding) procedure is great! The head looks terrific. Before I sanded, I was able to get a .002 feeler gauge between the head and a metal straight edge at a few places. After sanding though, it (appears at least) to be all level. Can't get a gauge under it anywhere. I know you SHOULDN'T be able to slip something as big as .002 gauge under it, but I don't have anything smaller and it seemed a more accurate way to assess where any high or low spots were as opposed to holding it up to the light and trying to see how much light showed between the straight edge and the head. Still have to re-check the points with a test light and then the head goes back on tomorrow, will torque all the bolts to 25, and then I'll see how the engine sounds.
Old 09-06-2017, 09:27 PM
While you have the head off I strongly recommend you remove and clean the valves and adjust them, this will probably have to be done by your brother since it's a bit involved.
Old 09-06-2017, 10:05 PM
Or at least adjust them.
Closed Thread
